Go to Post I'm a programmer by training and inclination, so my mechanical ideas are sometimes rather, um, loosely constrained by physical reality. - Alan Anderson [more]
Unread 10-01-2005, 17:23
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: how to wire the new two motor gearbox
That is one possibility, and would work. I used a y cable to test my dual motor winch last year. But you can also do this in programming. Thats what my team did with last years gearboxes which used the drill and cim. I would recommend the programming route, it would be more reliable to do it that way. If for some reason a cable becomes detached during the match, you are less likely to lose both pwm cables controlling one side. If you use a y cable, and the cable comes out during a match (say another robot accidentally does that, or it is just loose and comes out due to Violante driving), then you loose an entire drive side. Just the way I think about it.
Drok00 - well that depends on exactly how your transmission is set up, but if you are talking about the transmissions that come in the kit, both motors are spinning in the same direction.
"Jack of all trades, master of none, though offtimes better than master of one".
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Reliable Connections to the fuse blocks. Al Skierkiewicz Electrical 0 09-02-2004 12:01
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
