Strange CMUCam Image
We're experimenting with the CMUCam and have everything hooked up. There are no problems other than that the image recieved by the GUI app is completely messed up. We have gotten it to show the basic shape of an opject held in front of it, but no real image like that in the getting started guide. Any ideas?
Re: Strange CMUCam Image
sorry to say, but ours works fine, really good quality too, i suggest that you report that your cam is defective ASAP.
don't mess with it, just tell them it's not in working condition, and ask for a replacement (also i think it's obvious that you should mention that you are not responsible for the fault!) -Leav |
oooh! I had this same problem, check the baud rate and stuff on your serial port, go into the device manager and find the entry for com devices, then right click on the com port and go to properties, then under I think the second tab (sorry, not on my windows machine atm), make sure those setting correspond with the ones they give you on like the third page of the start here manual. this fixed my problems, the com port defaults are probably NOT what CMU cam requires
I thought I had tried this, but hearing the same problem from someone else — I'm trying again. Thanks.
Last edited by Sidney San Martín : 12-01-2005 at 23:56. Reason: Strange formatting |
From the troubleshooting part of the manual:
I get wavy lines or a distorted black and white image when I call dumpframe: This is most likely due to power. Make sure that you have a high enough voltage and that you are getting a clean signal. Running the camera off of fresh batteries not an AC adaptor) is a good way to test if this is the problem. |
Ours is working fine, but we cannot connect when it is also connected to the robot, so make sure something like this is not happening. Also, as mentioned before, check all power cables and make sure your baud rate is set right. If you have one, try testing the camera through a usb-serial adapter. While I have had problems with these when programming the robot before, we used another team members laptop equipped with an adapter today for the GUI, and it worked fine (although it was not COM1, rather COM4 but this probably varies). If this way of communication works, you will know that your standard serial connection is malfunctioning or not set properly.
#7
Ah yes, I also changed the battery, both of which may help. Run a volt meter to it and make sure the battery is giving you at least 7 volts. (The backup battery of course)
#8
We weren't having quite the same image problem but our images were very hard to distinguish.
We found that you can change the camera resolution to high if you go to the config tab in the software. I hope that helps. |
#9
From what I can tell, the CMU cam software is really cobbled together, I am hoping we can get the source, and try to fix it.
#10
when my teammates and I hooked the camera up for the first time, everything worked, but the image was really blurry. we found out that the camera has a manual focus, as in you just twist the camera lens. I don't know what kind of object you're trying to "see" there, however, and with those lines there I'm not really sure that this will help at all. but, if you run out of options, you can try to change it and see if it helps.
#11
I have not had any problems with it as long as you stop one task before starting another... |
#12
Seriously, though, if the double-press issue (or any other GUI glitch) is giving you a hassle, it shouldn't be too hard to fix. As a hack, you could probably throw a little finite state machine into the GUI interface software that either hides or ignores the stop button if the system is not in a state where stopping makes sense. As a student at CMU, I wish I could say "That bug shouldn't be there," but I've worked on too many projects like this to say that with a straight face . Not having been involved with the CMUCam project, my guess would be that it sounds like the hardware people assumed the software people wouldn't do something "obviously incorrect," and the software people assumed the hardware people wouldn't allow the camera to choke on "meaningless but well-formed input." Control system design teams, take note: there's a lesson here... As for me personally, given that the CMU cam is pretty awesome, and has the distinct advantage over other solutions of existing right now, I'm willing to forgive the design team for missing the "totally awesome" mark. If anyone decides to tidy up the software, share the fixes with the rest of us! Best of luck to everyone, Mark |
#14
if i get around to it, and if i understand the code, and if i learn how to execute java code, i promise to share the results with the community
#15
We still have yet to experience problems with the camera, aside from the fact that our color recognition is tenuous at best. And from what I've been seeing, we're not the only ones experiencing this problem. At least we still have decent motion detection, once you increase the threshold. We still haven't looked at the robot code implementing the camera yet, so we have no idea how that will run.
| New cool image generator | Elgin Clock | Computer Graphics | 13 | 03-11-2004 20:10 |
| Image Capture for Real Player? | indieFan | Chit-Chat | 12 | 22-06-2004 22:22 |
| Getting an image from a website | Raven_Writer | Website Design/Showcase | 17 | 09-06-2004 11:39 |
| extra image discussion text | rbayer | CD Forum Support | 15 | 06-05-2004 19:04 |
