Go to Post There hasn't been an announcement to buy pool noodles yet. Considering that they are already out of stores in most of the country, draw whatever conclusion that you like. - Joe Ross [more]
Unread 10-01-2005, 17:06
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
how to wire the new two motor gearbox
i tried doing a search, but didn't know what exactly to search for
we never tried a two motor gear box system before, but how do you wire the two motors on the gear box so that its controlled by one joystick (one joystick controls rights side gear box, other controls left side gear box). I know you can only put one motor for each speed control, now we have two motors and two speed controllers for each gear box, do we just use a y connector to hook up the two speed controllers to one of the output of the robot contoller outputs?
thanks
Unread 10-01-2005, 17:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: how to wire the new two motor gearbox
I'm not sure about the rules but from a possiblity standpoint, it will work to use a PWM Y cable. A better (and definitely legal) way would be to use separates PWM cables and outputs on the robot controller, then duplicate the part of the programming that makes the one output work so you have the signla on both outputs.
Unread 10-01-2005, 17:21
Drok00 Drok00 is offline
Guy With Fluffy Hair
AKA: Jason Petrilla
FRC #0698 (Grizzly Bots)
Drok00 is on a distinguished road
Send a message via AIM to Drok00
but aren't the motors spinning in opposite directions? if you used a Y cable wouldn't you then be sending them the same signal thus they would be trying to spin in the same direction?
(This is my first year, sorry if I'm way out in left field here)
Unread 10-01-2005, 17:23
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
That is one possibility, and would work. I used a y cable to test my dual motor winch last year. But you can also do this in programming. Thats what my team did with last years gearboxes which used the drill and cim. I would recommend the programming route, it would be more reliable to do it that way. If for some reason a cable becomes detached during the match, you are less likely to lose both pwm cables controlling one side. If you use a y cable, and the cable comes out during a match (say another robot accidentally does that, or it is just loose and comes out due to Violante driving), then you loose an entire drive side. Just the way I think about it.
Drok00 - well that depends on exactly how your transmission is set up, but if you are talking about the transmissions that come in the kit, both motors are spinning in the same direction.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 10-01-2005, 17:26
As for direction of rotation, you can "fix" this in programming or reverse the wires on the MOTOR side of the Victor speed control. Never reverse the wires on the power side of the speed control.
Unread 10-01-2005, 17:40
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
I'm going to have to second that one. Also, make sure that power from the breaker panel is going to the power side of the Victor instead of the motor side. We made both of those mistakes in one evening last year, but hey, at least we got to take a Victor apart and see what makes it tick.
Unread 10-01-2005, 17:45
AKA: Jason Petrilla
ahhh thanks!
Unread 10-01-2005, 18:48
occra 23.
AKA: ryo
None #1481
but victors arent supposed to tick! maybe hum yes but no ticking.
Unread 13-02-2005, 10:48
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
The 2005 victors must have polarity protection. We had several of them wired incorrectly and were wondering whythe panel kept tripping every time we turned it on :-D. However, when we switched the wires, they worked fine, and we have not had victor problems this year.
Jonathan
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
Unread 14-02-2005, 00:57
Andy A. Andy A. is offline
Getting old
FRC #0095
I have a suspicion.
Spikes come in two flavors. Red and Blue (the labels are diffrent colors). The difference between them, according to IFI's website, is that Blue spikes have reverse polarity protection. That is, wiring 12v+ to the common stud won't kill it. Otherwise, red and blue versions are the same.
Victors come in two flavors. Red and Blue. According to IFI's website, there is no difference, or at least I haven't seen any published note about there being one.
Could it be that blue IFI components are reverse current protected? I'm not ready to test that theory... Just remeber, if you toast a victor, don't blame me!
As for the 'Y' cable, it is legal for competition. I believe some came in the kit, or have in previous years. They seem to always come with a yellow signal wire. While I would recommend using 4 separate outputs, I can't think of a really good reason to. I've always liked the idea of being able to trim each motor independent of the other, but I doubt it's ever necessary. I'm sure theres a really good reason to do it, although I can't think of it. My gut tells me to keep all your PWM outputs separate.
One man, one vote. One motor, one signal. Or something like that.
-Andy A.
Unread 14-02-2005, 07:30
The dual motor transmissions have both motors feeding the same driven gear and therefore run in the same direction. A simple "Y" feeding two Victors should work IF you calibrate the controllers.
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Reliable Connections to the fuse blocks. Al Skierkiewicz Electrical 0 09-02-2004 12:01
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
