Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 10-01-2005, 19:04
Umm Errr...
Re: Pneumatic Confusion
Originally Posted by Cyberguy34000
Pneumatics are something that I thought I had a pretty good idea of how they worked, but as I'm reading more and more of the posts on this form I'm questioning if I know them as well I think I do. I'm considering proposing an arm design at tonight's meeting that involves 3 pneumatic pistons. One for the base, another for the elbow, and the final one for the grabber. As I understood it, pneumatics work by controlling the releasing of pressurized air to manipulate movable pistons which when they become pressurized, expand.
But is the process controllable enough to be used on something that needs a great deal of prison and control, such as a joint in an arm? Can you acurately control the joint of the arm or would it only have one of two extremes? Please help.
In most circumstances, pneumatics can only be positioned at their extremes. There are ways to position them midway, But i would not recommend it for an arm. Motors would be a much better way to go
1139 Alumni
Unread 10-01-2005, 19:26
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
I dis, and do agree with this statement. Motors do work well at controlling positioning. In fact that is all Sparky has ever used for controlling an arm. Very evident in Sparky 2, and 5. Both used in manipulation of 2x multiplier balls. There is one way that you can very effectively control the positioning of a pnuematic cylinder. The catch is that with using it as a contorler for an arm, you might have some issues with pressure. In my opinion, I find that both ways can be very productive ways of controlling an arm. And if you really want to use air, just marry 2 pistons together to get the desired mid-position stop you want, just like Moe did last year.
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 10-01-2005, 22:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you choose to use pneumatics to do this, there are a few good discussion threads from January and February 2004.
Also, some other sources -
www.cyberblue234.com / go to the multimedia and there is a video of pneumatic staging (ie starting and stopping mid-point on the travel).
also check the white papers, technical section, for a slide on the pneumatic circuit layout to do this staging. the title is "Controlling Pneumatics - Sketch".
I am the author of the file upload if that helps the search. It was uploaded in January or February 2004.
Basically, you control the movement of the cylinder by controlling the exhaust of the solenoid valve. I believe the slide shows doing that with two switches - one to control the direction and one to start and stop the cylinder. We ended up finding a way to link the solenoids and control it with one 3 way switch (extend - hold - retract).
It is difficult to repeatedly go to the exact same stop point. Air is very compressible, so the cylinder might move a little. Most cylinders were more accurate in one direction - depending on how they were loaded.
Good Luck. Take some time to experiment.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 11-01-2005, 03:33
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
I am not sure why more people do not know about this, but SMC offers a valve that looks just like the double solenoid but functions slightly differently.
The valve I am talking about has a center off/center pressure/center exhaust feature. Meaning you can have variable piston position using only one valve (not sure if you can get away with one relay quite yet).
The part number differs only slightly from the regular double solenoids. If you are interested, drop me a line. The only catch, currently (as of today) they are on a 4-6 week back/manufacturing order from SMC in japan as no one in the US has any in stock. This valve also fits on the manifold we used last year. (I should also note that those are not in stock either!) Argh
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
pneumatics archiver 2000 1 23-06-2002 22:42
pneumatics? archiver 2001 5 23-06-2002 22:18
