Go to Post Sometimes it's not about being fair. Some people are just very good at what they do. - Koko Ed [more]
Unread 10-01-2005, 19:07
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
Re: Problems with transmission using Inventor 8
I suggest downloading the STEP or IGES files for these parts if you don't want to wait to see if Autodesk will make Inv 8 versions available. Inventor hung when I tried to import the IGES files, but I could open the STEP assembly OK (takes a while to translate). You have to enable the STEP translation add-in to open them (Tools menu: Add-Ins...).
thanks this is just what i needed... i'm running inventor 5 (my own) and i'm supposed to draw up the robot and stuff and i wouldnt have been able to work the parts without this... THanks a lot
Nick .R. (Team 1009)
FRC Problems, will not work nevrgonastopme0 Programming 4 04-02-2004 21:01
Inventor problems Rickertsen2 Inventor 8 29-01-2004 16:48
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
Problems Installing Inventor Adam Shapiro Inventor 8 17-01-2003 22:45
