Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 08-01-2005, 20:44
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Problems with transmission using Inventor 8
Anyone else having problems opening up the inventor drive train and transmission parts? I have inventor 8 and i am getting this message when i try and open it
Database Schema is newer than this version of the software.
I cant see them taking the time to do all of this in 9 and then give all the teams 8.
The IFC site where you can get it is http://www.ifirobotics.com/kitbot.shtml
Drew Hopman
Unread 10-01-2005, 08:59
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Problems with transmission using Inventor 8
IFI did use Inventor 9 for their model. Transmission_Assy.iam opened without any problem with 9. I attached a screenshot of what we're missing with Inv 8. Looks like most of their parts are based on models imported from some other application, rather than designed in Inventor.
I suggest downloading the STEP or IGES files for these parts if you don't want to wait to see if Autodesk will make Inv 8 versions available. Inventor hung when I tried to import the IGES files, but I could open the STEP assembly OK (takes a while to translate). You have to enable the STEP translation add-in to open them (Tools menu: Add-Ins...).
Pete Kieselbach
Unread 10-01-2005, 10:00
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
This is exactly how they were originally made.
New Inventor 8 versions will hopefully become available soon. Until then I recommend all teams use the STEP files, and import them.
Unread 10-01-2005, 10:26
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
Let me clarify some things for people:
1. Whatever JVN or I say regarding the kit chassis or the transmission should be treated like it is coming from the source, because he and I were the source (or sources).
2. John took his chassis components designed in ThinkDesign 8.4 and brought them into Inventor 9.
3. I designed all the transmission parts in SolidWorks 2004 and converted them to STEP and sent them to John. He brought tem into Inventor 9.
The bottom line is that the STEP files are the best files to use.
-Paul
Unread 10-01-2005, 19:07
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
thanks this is just what i needed... i'm running inventor 5 (my own) and i'm supposed to draw up the robot and stuff and i wouldnt have been able to work the parts without this... THanks a lot
Nick .R. (Team 1009)
FRC Problems, will not work nevrgonastopme0 Programming 4 04-02-2004 21:01
Inventor problems Rickertsen2 Inventor 8 29-01-2004 16:48
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
Problems Installing Inventor Adam Shapiro Inventor 8 17-01-2003 22:45
