Go to Post The robots that rise to the top will not be the ones that do everything poorly, but the ones that are breathtaking at one thing. Be that robot. - DampRobot [more]
Unread 10-01-2005, 19:12
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Pneumatic Confusion
Originally Posted by Cyberguy34000
Pneumatics are something that I thought I had a pretty good idea of how they worked, but as I'm reading more and more of the posts on this form I'm questioning if I know them as well I think I do. I'm considering proposing an arm design at tonight's meeting that involves 3 pneumatic pistons. One for the base, another for the elbow, and the final one for the grabber. As I understood it, pneumatics work by controlling the releasing of pressurized air to manipulate movable pistons which when they become pressurized, expand.
But is the process controllable enough to be used on something that needs a great deal of prison and control, such as a joint in an arm? Can you acurately control the joint of the arm or would it only have one of two extremes? Please help.
The easiest method is to have the joint move between mechanical stops that are just far enough apart to keep the piston of the pnuematic cylinder from bottoming out. This leaves basically two positions.
However a number of people from this forum have used different scemes for achieving control of intermediate positions. There were extensive discusions on this last year. If you search the archives for "multi-position" you should find them. I' am not sure how precise the control is. My own experience is that the intermediate stop would be pretty imprecise. But if you use feedback from an encoder you might be able to improve that alot.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 10-01-2005, 19:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You may want to check out www.pneumaticsfirst.org and setup a little system and see what it does. It shouldn't take any more than 20 minutes to get one cylinder and assorted parts hooked up. If you want to see even quicker than that, take the colored plugs out of the holes of the clyinder in the kit and place your mouth on one hole and blow. If nothing happens try the other end. Don't inhale or lick your lips afterward because there is oil inside and may be a little on the outside.
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
pneumatics archiver 2000 1 23-06-2002 22:42
pneumatics? archiver 2001 5 23-06-2002 22:18
