Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Unread 10-01-2005, 19:18
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
Re: Inventor problem! Dimension Error
Originally Posted by sanddrag
I'm still guessing that it is either a graphics card, or graphics card driver incompatibility issue.
No it can't be that, because I used inventor for two or more months before this happened. I never changed my graphics card.
"freedom is voluntary self control” Mahatma Gandhi
Unread 10-01-2005, 22:34
squeeks548 squeeks548 is offline
Sean Bodrie Robostangs #548
#0548 (Robostangs)
squeeks548 is on a distinguished road
Yea I have no idea what is going on i un-installed and re-loaded and it still does the same thing. Inventor 6 worked and now 7 does this so i have a few choices, go back to 6, or go to 8 or 9. The only problem with going up is that when i try to bring it from my computer is that it might not work with version 6 that is at school. This is why i am leaning with just going back to 6. thanks for all of the help. One of my mentors said it might be memory or harddrive space but with 1 gig of memory and 40 of harddrive space i don't think so. oh and i went to the autodesk and is says that the graphics card and driver will work so that eliminates that.
sean
Unread 11-01-2005, 07:32
Have you gone to the Autodesk site for help? See this...
http://usa.autodesk.com/adsk/servlet...linkID=4183228
Are you running 98 SE like this suggests.
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Error in Visual C++ Ashley Weed Programming 15 06-05-2004 14:53
Strange 16 bit MS-DOS subsystem error Crazy_Ed Programming 6 18-03-2004 14:31
strange error Anthony Kesich Programming 2 25-02-2004 18:55
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
