Go to Post Remember that starting a team is ALOT of work, but it’s a lot of fun once it gets going. Its all about the students, so don’t get too carried away ;) - Travis Covington [more]
Unread 10-01-2005, 19:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Pneumatic Confusion
You may want to check out www.pneumaticsfirst.org and setup a little system and see what it does. It shouldn't take any more than 20 minutes to get one cylinder and assorted parts hooked up. If you want to see even quicker than that, take the colored plugs out of the holes of the clyinder in the kit and place your mouth on one hole and blow. If nothing happens try the other end. Don't inhale or lick your lips afterward because there is oil inside and may be a little on the outside.
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
pneumatics archiver 2000 1 23-06-2002 22:42
pneumatics? archiver 2001 5 23-06-2002 22:18
