Go to Post Eription- the condition of shredding the eardrum from excessive cheering at robot competitions - Wayne C. [more]
Unread 10-01-2005, 22:16
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Pneumatic pressure switch
Im not sure if this should be in the programming or pneu thread.
Forgive me if im wrong, i havent slept in about 23 hours.
When i was paging through the manual, did I see that the code for the pressure switch is not in the default code? I can not say i know a great deal about coding, im crossing over from the mechanical threads. But is it in there? and if not, how is one supposed to keep pressure? i dont think trying to keep taps on how many times you fire the cylinders to how much time you charged the compressor will work well, untill someone blows the relief valve.
sorry for rambeling, i cant see straight
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 10-01-2005, 22:23
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Pneumatic pressure switch
The pressure switch has two settings.
At the high point (115 - 120 usually), the sensor will send a signal to the control. At this point, the compressor should be shut off.
As you use pneumatics, the pressure will drop. When you reach the low set point (100 - 105 usually), the compressor will come back on. Unless something malfunctions, you should never trip the relief valve.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 10-01-2005, 22:45
M. Hicken's Avatar
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
nono, i know how they work, they will cut back on at 95 psi. my question is, is that coding in the master default code. i couldent seem to find it, or am i thinking about it too much, and it is an on off switch, and no coding needed?
Unread 10-01-2005, 23:09
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Code for compressor control has never been in the default code (believe it or not). What *is* in the default code is software that turns on and off defined relays in response to defined digital inputs. There is also code that outputs values to defined PWM channels based on input values from defined joysticks. Various other digital inputs are coded to provide limits on some of the joystick to PWM "connections".
It is up to the hardware designer to figure out which digital input the pressure switch should be connected to and which relay output the compressor should be driven from. Then you can run the default code.
Otherwise, your hardware designers can tell the software folks which digital input will be the pressure switch and which relay will be the compressor and custom software will need to be written to monitor the state of the digital input and drive the state of the relay to accomplish a control loop.
The default code is sufficient to implement a robotic control system, but you need to wire the controls to fit within the "connections" made between inputs and outputs as defined in the default code reference manual. Nothing fancy is included and no autonomous mode is present.
To get autonomous mode stuff, you go to kevin.org for the PID control loop and command sequencing stuff. That code has its own assumptions about what inputs and outputs are connected to what. It must all be read and understood before anything is actually wired in and/or software loaded.
That's where the rubber meets the road (or the tires meet the carpet) and the real fun begins!
Unread 11-01-2005, 00:21
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
[quote=ldeffenb]Code for compressor control has never been in the default code (believe it or not). What *is* in the default code is software that turns on and off defined relays in response to defined digital inputs. There is also code that outputs values to defined PWM channels based on input values from defined joysticks. Various other digital inputs are coded to provide limits on some of the joystick to PWM "connections".[quote=ldeffenb]
Last years default code did have relay control defined, for the last relay and the last digital input, as I recall. I also remember that the positive and negative were reversed in an early version. The spike driving the compressor was Red so the fan on the compressor ran backward. I do remember reading the comments in the code telling you where to connect the spike and the switch. Can't say the same for this years code as I haven't looked yet. If you want all the details search the old forums Or look in 2004's default code.
Unread 11-01-2005, 00:27
The pressure switch code is in the 2005 default code. It's so simple that it's easy to miss.
relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
Hook the pump to relay 8 and the pressure switch to digital input 18 and you're good to go.
Unread 29-01-2005, 20:42
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
How are we supposed to connect the pressure switch to digital input 18?
our web site
Unread 29-01-2005, 21:34
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
all you have to do is cut the end of a pwm cable off and connect the two wires to the switch and the other end of the pwm cable to the controller on a digital input.
Unread 29-01-2005, 23:09
FRC #0939
Team Role: Student
Which wires do you hook up to the switch though? Red, white, or black?
our web site
Unread 29-01-2005, 23:35
The pressure sensor/switch has two contacts. One of these (either one) connects to the ground pin (black PWM wire) on the RC, the other connects to the Signal pin (white PWM wire).
The center +5v or red wire is not used for this purpose.
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
