| My love is autonomous when you enter the room. |
#16
Re: Tetra Math
Re: Tetra Math
Re: Tetra Math
anyone know what the angle is between faces? I drew a tet in AutoCad and I measured it to be 55 degrees, but I think there is something wrong with this.
Lucid |
#19
Re: Tetra Math
The angle can be calculated by looking at a cross section of the tetra, giving 2*arcsin(1/sqrt(3)), which is approximately 70 degrees.
#20
Re: Tetra Math
I love math, algebra and trig me = nerd ![]() |
#21
Re: Tetra Math
Re: Tetra Math
think about it here, 6 inches, thats half a foot. Even with end caps at the largest constraint is 4 inches. It is physicaly impossible for it to be a six inch increase per tetra. IMPoSIBLE!!!!!!!!!!!! unless someone put it on a freaky way
#23
Re: Tetra Math
We've also built tetras...it is 6". The sides of one tetra do not even come close to being flush up against the sides of the one below it. I think it is partially because the sides of the lower one get jammed into the corners of the one on top.
#24
Re: Tetra Math
Re: Tetra Math
I wish i had seen this thread sooner. I had to do this math today but oh well i like math. Nice thread.
#26
Re: Tetra Math
ok i believe it is 6 inches, but wait, how thick are your pipes. The manual said they should be 1 and a quarter inches at pipe and 1.(4-9) inches at endcap
or...maybe...how long are the pipes themselves? 40"? 48"? 70"? Last edited by sojouner06 : 12-01-2005 at 22:38. |
#27
Re: Tetra Math
http://www.ifirobotics.com/first-2005-field-parts.shtml
look here for the parts first wants you to get |
#28
Re: Tetra Math
Re: Tetra Math
ok, it is 6 inches, but i am still baffaled! how can the formula i used be wrong???? what could be an outside influence to change the height so drastically...
#30
Re: Tetra Math
To clarify angles a bit:
The angle between a face and an edge is ~55 degrees. The angle between two faces is ~70 degrees. |
| Electromagnets to pick up tetra? | xxerin | Rules/Strategy | 26 | 10-01-2005 07:30 |
| White Paper Discuss: 296's CORDIC Math Library | CD47-Bot | Extra Discussion | 5 | 28-04-2004 20:01 |
| Math project | edomus | General Forum | 4 | 01-04-2004 13:12 |
| Logical statements or math formulas | Manoel | Programming | 1 | 16-02-2002 23:29 |
