Re: Semi-Tank Tread/Half Tank Treads
We are trying to find the best balance between turning and carpet grip(pushing power).
Well, the thing about treads is that they only apply force to the carpet where the pulley (wheel the drives the tread) is pushing the tread into the ground. In essence, a tread design with 4 pulleys total would have the same contact with the ground as a 4wd bot (given that wheel size and pulley size are equal). Of course, this topic has already been discussed in threads like http://www.chiefdelphi.com/forums/sh...ad.php?t=31438 . Hope that helps.
| Has 6 wheeled designs surpased tank treads | Andrew Schuetze | Technical Discussion | 60 | 27-04-2005 17:29 |
| Tank Treads | dddriveman | Kit & Additional Hardware | 27 | 06-05-2004 18:16 |
| Major problems with tank tread drive | Lord Nerdlinger | Technical Discussion | 13 | 23-02-2004 21:15 |
| tank treads vs. threaded wheels | lj8758 | Technical Discussion | 14 | 24-01-2003 00:30 |
| TANK TREADS...welp. | archiver | 2001 | 13 | 23-06-2002 22:50 |
