Go to Post Time to iterate, more. - jwfoss [more]
Unread 10-01-2005, 01:11
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Semi-Tank Tread/Half Tank Treads
Hi,
Apoligies if this topic has been posted; however, i did not find a topic that could benefit my interest
I would like to know if any of you have used sem-Tank Tread drivetrains in combination with casters, omni wheels or anything else, please let me know anything you know about this subject. Pictures will be superb.
Thanks in advance!
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 10-01-2005, 02:27
REVving up for a new season
FRC #2848 (All-sparks)
Re: Semi-Tank Tread/Half Tank Treads
i have seen this design before you can possibly find pictures of robots at www.firstrobotics.net
but i must ask what the point is....you would get the same affect as wheels with casters especally with the smaller base size this year. all you would be adding is complexity to your system
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-01-2005, 02:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I believe the link is www.firstrobotics.net
Unread 11-01-2005, 07:58
thoughtful's Avatar
We are trying to find the best balance between turning and carpet grip(pushing power).
06-Team 1219 Mentor
Unread 11-01-2005, 08:33
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Well, the thing about treads is that they only apply force to the carpet where the pulley (wheel the drives the tread) is pushing the tread into the ground. In essence, a tread design with 4 pulleys total would have the same contact with the ground as a 4wd bot (given that wheel size and pulley size are equal). Of course, this topic has already been discussed in threads like http://www.chiefdelphi.com/forums/sh...ad.php?t=31438 . Hope that helps.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
