Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 10-01-2005, 20:18
Nucks Nucks is offline
'Nucks
#1347 (Trobotics)
Nucks is an unknown quantity at this point
Are we given sufficient sensors in the kit?
There's the accelerometer, and the Hall Effect Sensor (2).
Are these two sufficient for sensors on the robot, and if not, what else would be useful?
Edit: My teammates seem to recall from the kick off video that the sensors provided in the kit would be sufficient, this is why i'm asking.
Thanks for replies
Unread 10-01-2005, 20:31
Electrical Engineer
Rookie Year: 1995
Re: Are we given sufficient sensors in the kit?
Thanks for replies
It is evident (by inspection of the code and inspection of the kickoff video) that the kickoff robot had gyro sensors and encoders installed. Neither of these sensors were included in the kit.
JMHO.
Mike Betts
As easy as 355/113...
Unread 11-01-2005, 07:15
Something that helps software out is knowing where certain parts of your robot are. Pots (variale resistors) connected to moving arms, steering mechanisms, etc. can report back to software and help modify robot reactions and assist in auto modes.
Microswitches can be used to limit travel or sense when a moving part has just about reached it's mechanical limit.
Wheel encoders/shaft encoders can be used to tell how far you have driven.
Unread 11-01-2005, 07:51
Zanella BR's Avatar
Zanella BR Zanella BR is offline
Brazillian FIRST Team Member
AKA: Leandro Zanella S. Campos
None #1382 (Tribotec)
Zanella BR will become famous soon enoughZanella BR will become famous soon enough
Send a message via ICQ to Zanella BR Send a message via AIM to Zanella BR Send a message via MSN to Zanella BR
Thanks for replies
It depends on what you wanna do.
For the demonstration in the kick off I think the kit can be enough, depending on the programming and way of use.
Obviously, you'll need more sensors for monitoring an arm, for example, or other specific function.
The Lightning Hunter
#1382
2004 - NJ Regional -3rd place (Rookie year)
2005 - NJ General Motors Industrial Design Award
2005 - NJ Website Excellence Award
2005 - NJ Safety Award
[<o>]
Brazil's 3rd Team
Unread 11-01-2005, 07:58
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
There is no gyro in the kit?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 11-01-2005, 08:39
Electrical Engineer
Rookie Year: 1995
Originally Posted by Zanella BR
For the demonstration in the kick off I think the kit can be enough,...
Leandro,
I believe that the demonstration robot used a gyro and encoders. Neither were in the kit. If you want to use them, you have to buy them.
Mike Betts
Unread 11-01-2005, 08:41
Electrical Engineer
Rookie Year: 1995
No.
Mike Betts
Unread 11-01-2005, 08:44
Zanella BR's Avatar
I know that a gyro can be used, actually I already used in an old project. I haven't read all about the sensor of this year's kit (which is not here yet), but I suspect that you can use for that function.
#1382
[<o>]
Brazil's 3rd Team
Unread 11-01-2005, 08:46
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Originally Posted by Mike Betts
Leandro,
While a gyro sensor is not given in the kit and neither are sensors labeled "encoders," FIRST does provide an accelerometer and 2 hall effect sensors. The accelerometer, with the right fine tuning, can give feedback similar to that of a gyro. Additionally, the hall effect sensors basically are wheel encoders.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 11-01-2005, 15:16
I'd rather have the Silicon Sensing Systems GYRO-CRS03 gyro and Grayhill 61K128 encoders the kickoff robot used.
Unread 11-01-2005, 15:26
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
In the kick-off they said we have all the sensors we need inside the kit. they said we\d be getting a PID controller. does anybody know where that is? I can't seem to find it in the code.
How can the Acceleration meter be used as a gyro?
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
troy_573 troy_573 is offline
Team 573 (No Place Like Home)
AKA: Troy
FRC #0573 (The Mech Warriors)
troy_573 is an unknown quantity at this point
Send a message via AIM to troy_573
are we allowed to purchase our own gyro sensors ... from what i understnad is that the gyros were not allowed
Unread 11-01-2005, 15:30
Yes, you are allowed to purchase gyros just like last year as long as they meet the vendor and cost rules.
Unread 11-01-2005, 15:47
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
The PID system is available along with the scripting at www.kevin.org/frc. In my humble opinion, an accelerometer is a very poor substitute for a gyro. Last year we ended up disconnecting our accelerometer because all it did was eat up processing power. Remember the cool thing where Lavery jarred the robot, and then it righted itself? In my experience, accelerometors tend not to register sharp hits accuratly, they either over-, or underestimat the severity of the movement.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 11-01-2005, 21:56
'Nucks
#1347 (Trobotics)
I'm not clear myself what a gyro sensor is, from what I've read and looked through, its some rotation sensor of some sort?
Anyone want to help clarify this for me?
Coding CDs in the kit -- What'd you get? elyscape Programming 1 08-01-2005 14:31
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
