Go to Post Dave Lavery says it's pimp? I don't care if the Pope says it's pimp, it still doesn't pass inspection! - MissInformation [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2005, 11:13
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: That is easy for you to say...
Originally Posted by Mike Betts
If we believe the specs, the FP motors are over 400W each. If this holds true, they are going to get hotter than Hades insummer if and when they stall or run under high torque.
And that temps gonna climb real fast!
I love the smell of burnt motors in the morning!
Last year, two of these motors were enough to lift a 130 lb robot six feet off the floor in seconds. So you should be able to easily lift 10 tetras at a time to a height sufficient to cap a goal.
You have more than enough power available, the question is "Can build a structure that can handle it and still meet weight requirements?" or "Can you build a gripper that will hold 10 tetras?"
Remember P=F*d/t
Where P=power
F=force
d=distance
t=time
Given enough time, even the weakest motor could lift anything any distance. Decide how much you want to move and how far you want to move it. Then figure out how fast you need to move it. That will tell you how much power you need.
The FPs are vastly underrated by the FIRST community at large, but those of us who have bent 1.5"x1"x1/8" aluminum C-channel with them have great respect for them.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 12-01-2005 09:04
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
