Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 16-12-2004, 22:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Electrical Schematic/ Wiring diagram
I'm wondering do any teams make an electrical schematic of their robot? The generic one FIRST provides is nice, but I think it might not be a bad idea for every team to make one specific to their robot to present at the time of inspection. What do you think of that?
Also, is there any good software for making electiral schematics?
Last, on a semi-related topic, does anyone model their wiring in Inventor? If so, can we get some screen shots?
Thanks.
Unread 17-12-2004, 07:41
Re: Electrical Schematic/ Wiring diagram
Sanddrag,
We have always talked about making a schematic but the FIRST one is sufficient. When we have a problem, we are not going to pull out the schematic and try to determine a cause. By color marking everything we can easily make a determination of a problem. When I say "everything" I mean PWM cables, PWM positions on the RC, fuses and block, speed controllers and spikes, primary and secondary wiring and motors, solenoids, servos, sensors and lights.. Wiring is coded at both ends. We know that if the red motor is running and shouldn't be, we can pull the red fuse and it should power down. If the red motor isn't running and it should be, we check to see if the fan is spinning on the red controller and it has "happy lights", if the red PWM cable is in place at the controller and the RC, and if the red fuse in in place in the red position on the fuse block.
If I was going to draw out a diagram, I would use Autocad since it readily available for me.
Unread 17-12-2004, 08:44
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
I think there was some software that came from Autodesk last year that allowed you to make wiring schematics, and could even test if a circuit would work. Sorry, but I can't think of the name of the software immediately, although it may have been Autodesk VIZ.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 18-12-2004, 17:56
Lindsey Lindsey is offline
Lindsey will become famous soon enough
Every year we have made a wiring diagram.
In the past we have used Auto CAD, because it was available. Last year we used the new Viso software provided in the kit. I found it easy to learn, my favorite part is the dynamic connecting, when you move components around the wires automatically reroute them selves and stay connected.
Lindsey
Unread 19-12-2004, 02:12
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by Al Skierkiewicz
Sanddrag,
looks like 111 did make a schematic of sorts....http://www.wildstang.org/2004/invent...MSchematic.gif
Unread 19-12-2004, 11:35
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Last year, we took the FIRST schematic and highlighted the parts we wanted to use (and drew in by hand a little bit extra). In the future, what I think may be useful would be less of a schematic, and more of a model or "map" of the system that would show you the physical locations of the parts so you could very quickly find them. Al Skierkiewicz's color system would serve a similar function, but knowing our wiring last year, it wouldn't always be possible to even see all the components.
Team 1257
Unread 19-12-2004, 12:11
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
For the Robocards every year they have made a wiring diagram via Autocad. Helpful for making a presentation for getting sponsors, but usually they have a certain color code for each part of the electrical system. Just makes it 1000x easier instead of having to pull out a wiring diagram when you are in the pits...
That rug really tied the room together...
Unread 11-01-2005, 09:27
Nixterrimus Nixterrimus is offline
AKA: N. Rowe
#0578 (Blue Lightning)
Nixterrimus is on a distinguished road
Send a message via AIM to Nixterrimus
FIRST has now posted a wiring diagram on their website, you can find it at:
http://www2.usfirst.org/2005comp/Dra...STRIBUTION.pdf
Unread 11-01-2005, 09:40
Last year, we used acrobat to modify FIRST's existing schematic to show our configuration.
Unread 11-01-2005, 12:51
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
We made a electrical diagram last year..........it rocked.......we also made a point to make it look exactly like it was on the robot (instead of just making it look close). Our wiring was so organized it was NICE .
I believe that every wire should be labeled to what it goes to, and also all the wires should be organized neatly. Like in one line with wires coming out where they need to.
I totally disagree with just wiring a robot a not even organizing the wires and leaving them hang. First of all it causes hazards, and second of all it is very hard to fix something electrical in a rush.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
Competition port Wiring diagram Joe Clohessy Technical Discussion 14 20-05-2003 12:14
Electrical wiring layout sheet George T Electrical 1 11-02-2003 18:20
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
