Go to Post Ask questions; don't be afraid to talk to "powerhouse" teams. - CalTran [more]
Unread 11-01-2005, 08:18
Squall Squall is offline
Squall is an unknown quantity at this point
Ball Shooter
Hello,
Our team was thinking about using some kind of device that can shoot a ball for a specific function.
The ball would be attached to the robot by a nylon cord and it would be something like a small tennis ball so that we can make sure that it cannot harm anyone in case of some kind of failure.
It would roll the cord back so that the ball would be back in the robot after it has been shot. And the cord won't exceed the field size.
Do you know if there's something against this in the rules ?
We couldn't find anything, but it's always better to be sure.
Thanks a lot.
Girafales - TEAM #1382
Unread 11-01-2005, 08:25
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Ball Shooter
I know that last year, the rule on somthing shooting through the air was that it had to be under 10 feet per second. However, no rule regarding that exists currently (though you're not allowed to throw the tetras period). I would ask that under the FIRST Q&A. Something to consider however is that a ref could disregard FIRST's rulling, deeming your device a safety hazard. (He would be well within his rights to do so). I would not design a robot that depends on functioning in the gray areas.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 11-01-2005, 10:12
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Ball Shooter
Do you mind explaining what the use would be for, different uses will referance different rules.
-Michael Dessingue
Unread 11-01-2005, 10:24
Re: Ball Shooter
We're thinking about using it to shoot the ball at the tetras in autonomous mode.
Unread 11-01-2005, 10:28
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Ball Shooter
Im not sure that they are going to go for a robot shooting a ball autonomously. Thats just my opinion though.
Unread 11-01-2005, 10:34
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Ball Shooter
I would say any use like that would be illegal. If not for the projectile itself, but any cord extended out and away from the robot poses an entanglement hazard.
From <R25>: Mechanisms or components on the robot must not pose obvious risk of entanglement. If, in the judgment of the inspectors, a device on the robot poses an entanglement risk then the team will be required to remedy the situation before the robot will be allowed to play.
Unread 11-01-2005, 10:59
Re: Ball Shooter
Well then thanks, we won't go for this.
Thanks for helping anyway.
Unread 11-01-2005, 14:47
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Ball Shooter
A little birdy told me though, that if you just simply drive into the Tetra Goal with enough force (re: very little) then the magnets that hold them (which are suprisingly weak) will let go, and the Tetra's will just drop.
Ball Shooter Squall Kit & Additional Hardware 0 11-01-2005 06:52
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
