Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 11-01-2005, 15:07
Aalfabob's Avatar
Aalfabob Aalfabob is offline
#0201 (FEDS)
Aalfabob is on a distinguished road
Send a message via AIM to Aalfabob
Using multidimension arrays?
I made some code that involves a multi dimension array, and the compiler is coming up with a syntax error.
ATan [32,32];
Are there anyways to fix this so that I can use the array?
Unread 11-01-2005, 15:15
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Using multidimension arrays?
ATan [32,32];
This is incorrect C syntax. You want to write that as follows.
ATan[32][32];
More info about arrays can be found by looking here.
Arrays on the PIC? scitobor 617 Programming 8 06-12-2004 09:10
EduCAD and Arrays!!!!! Sachiel7 Programming 14 03-11-2003 03:21
