Re: Driving Robots under/into the Goals ... allowed?
i would have to agree with you on that one... our team was discussing this issue as well. It sounds like (according to the rule) that your robot cannot extend a mechanism underneath the base of the triangle. Kind of like last year where u couldnt extend your robot underneath the mobile goal. But i suppose it would be ok to climb over the base and chill under the goal... just as long as u dont tip it over.
I think this means that if you go under a tetra for any reason, you cannot extend an arm or whatnot while your robot is under the tetra. This could malfunction, and they don't want your team getting a penalty for accidental damaging of the tetras.
--->i saw that too. i think that there is a small space between the ground and the goal frame since the tetra goals are made out of aluminum pipe and PVC end caps. the end cap causes the goal to rise a little. i think you are not allowed to go UNDER the goal but you can go INTO the goal. how else would you score the 1 point or knock tetras out of the goals?
FIRST Q/A ID 1078
Q:Can a robot be driven through a goal if it does not break any other rules? A:Yes |
We wondered about this also(the gap on the ground). The rules say that the middle goal will be secured to the ground with velcro(no gap). But, the other goals never mention about being velcroed down. We thought we could push a goal anywhere on the field...
Q:Will the large tetras, other than the center one, be secured to the floor with velcro? A:Yes. They have the Q/A section for a reason. |
#8
Also, beyond the Q&A, just look in another thread in the strategy section, stackable robots
| Robots compete in first match (FitN) | Clark Gilbert | FIRST In the News... | 0 | 24-03-2004 18:11 |
| FYI: FIRST Robots at the NYC Hall of Science | Rich Wong | General Forum | 9 | 11-07-2002 10:52 |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
| WOW ! | Mike Schroeder | General Forum | 12 | 12-03-2002 21:32 |
| Who's robots are driving already? | Anton Abaya | General Forum | 67 | 16-02-2002 00:07 |
