Re: How much weight is left?
Has anyone weighed all the motors, if so can they post all the weights together |
We finally got the frame assembled today. It weights about 12 pounds (without the plate that attaches to the gearboxes).
Re: Weight of the kit base?
Frame with just rails and hardware for connecting those rails: 10.35lbs
Motors: 9.75lbs ea. |
9.75 lbs per motor? No way. Thats a third of the weight just for motors..........
My bad! Sorry for the confusion. edit 1:The frame weight reference is correct though, I weighed that myself. edit 2: Then again, that was the long configuration for the frame, 38" length, and 28" width. Last edited by Elgin Clock : 11-01-2005 at 23:43. |
#8
I would really like to know the weight with frame, wheels ,motor, speed control, wire ,sprockets, chain , radio,and battery the complete base in running order .
thank for your weights that you have already posted. thanks jim schaddelee team 107 |
#9
The weight with the battery doesn't matter. We don't have to weigh in with it. Other teams have posted that the frame, gearboxes, etc all weigh in at 30 lbs. add maybe 5 pounds more for electronics and you should be looking at a reasonable weight. |
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| Coding CDs in the kit -- What'd you get? | elyscape | Programming | 1 | 08-01-2005 14:31 |
| need standard kit gearbox | Korbin | Kit & Additional Hardware | 0 | 15-11-2004 21:18 |
| Q&A Discuss: How many Van door motor(s) come with the kit? | CD47-Bot | Extra Discussion | 1 | 08-01-2003 11:07 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
