Go to Post Yeah.... I'll pay money just for a picture of Andy [Grady] getting jiggy! (then recommend it for the Caption contest!) ;) - Rich Wong [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 11-01-2005, 19:05
HolyOne207's Avatar
HolyOne207 HolyOne207 is offline
Domo arigato, Mr. Roboto
AKA: Brian & Peter
#0207 (MetalCrafters)
HolyOne207 is an unknown quantity at this point
Send a message via AIM to HolyOne207
Help - new interface, old servos
hey guys and gals. my partner and i have been trying to use the nw interface for the 2005 frc with the old servos from the robovation kit. the servos have a 4 pin connector with black, red, yellow and orange wires. however the new interface had a 3-pin connector with labels for a black, red and yellow/white pins at the relay outputs. the 4th-pin from the servo is the orange wire, which isnt labeled on the interface, and it makes the 4-pin connector from the servo too wide to connect onto the new interface. is there any suggestions? any help is appreciated.
your friend
Holy One
Unread 11-01-2005, 19:49
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: Dilemma!!! Please Help!!!
Off hand, I do not believe that the orange wire is needed . . .
However, if my memory serves, the EDU servos can rotate 360 + n degrees, so I would check the skematic before I pulled stuff off.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-01-2005, 00:06
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Help - new interface, old servos
your friend
Holy One
The "servos" from the robovation kits are actually servo-motors, which means that they will rotate at a given speed instead of rotating to a given position. Since these are more powerful than standard servos, the fourth wire provides the extra power they need. I would either use them with the Robovation controller if you need to use them as motors, or use the two Hitec servos that came in the kit with the 2005 robot controller if you need them to work as servos.
Zan Hecht
Unread 12-01-2005, 10:52
HolyOne207's Avatar
AKA: Brian & Peter
ok. another dilemma. we tried to use the new servos, but the old wheels that cam with the robovation kit have a square piece of metal for the axel. the piece of metal is needed for the wheel and in the old servos it went stright into them.
one more thing. i am going to use the extensions that came with the new kit to extend the old servos with a three wire and see what happens. ill see if there is a difference between that and running it with four wires.
Serial/Parallel Interface mchan1111 Programming 2 22-10-2004 23:36
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
how to create custom interface _GP_ Technical Discussion 1 18-01-2004 21:24
Looking for operator interface... Where is it? mike325 General Forum 2 07-01-2003 15:28
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
