Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 11-01-2005, 20:11
Electrical Engineer
Rookie Year: 1995
Re: Scripting Setup and the Camera + Serial Port Drivers
Originally Posted by CJO
...trying to integrate the Camera control system into the scripting code is becoming a real nightmare. The difficulty is in the serial port driver...
In defense of Kevin, First, Woody, et al, I expected nothing less. Engineering is all about trade offs. You can design yor system to do A, B or C easily. Combining A abd C or A and B or B and C requires some effort. Combining A, B and C should be near impossible.
If you try to use every motor and actuator in the kit, you will be about 60 pounds overwieight.
Set your priorities. What does this robot NEED to do? Now look at options. What will give you a winning design?
To quote an Eagle: Get over it...
Mike Betts
As easy as 355/113...
UTC Hartford and the Pits in 2001. The same setup for this year??? Elgin Clock Regional Competitions 3 01-11-2002 19:11
