Go to Post Stop. Breathe. Relax. QUIT STATING STUFF THAT YOU DON'T KNOW TO BE TRUE. - Rich Kressly [more]
Unread 11-01-2005, 17:58
FRC #0701 (RoboVikes)
Mabuchi motor gear specs?
as the title implies... i need some specs for the mabuchi motor ... i.e pitch diam... pressure angle etc.. etc..
Thank you... no gear info on the PDF @ mabuchi website...
Team 701
Unread 11-01-2005, 20:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Mabuchi motor gear specs?
It is HERE on page 4.
It is basically an impossible gear to mate with easily. 60 DP, 25 Degree Pressure Angle, enlarged. I don't know where to buy a 60 DP gear, yet alone a 25 PA version of one. I suppose you could find a close gear and (plug your ears) and let the gears "run in" but where's the fun in that.
I have already shared my thoughts on how to put this 7 Watt Wonder to good use. Look here.
More FREE ADVICE (and worth every penny ;-) from THE Dr. Joe, accept no substitutes...
Joe J.
Team #88, TJ2
Mabuchi Motor Specs Conor Ryan Motors 4 11-01-2005 10:50
2004 Motor specs - Part 1 Paul Copioli Motors 12 28-01-2004 17:40
Mabuchi Motor Specs Joe Johnson Motors 2 08-01-2002 16:55
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
