#16
Re: Inventor Tetra Connector
thanks a million guys, we have completed the side goals, but are still in a dead end when it comes to the centre goal, as we do not have any drawings of the centre couplet or the base couplet.
I will put up a drawing of the goal if we get how to make it, hopefully by tomorrow In the meantime, any help on how to make them will be greatly appreciated Last edited by FarooK : 12-01-2005 at 19:11. |
#17
please do post the completed tetra.........better to share our resources than try to build one from scratch.
#19
I tried opening that one that was posted, but when it opened, I could not see the part. Mousing over the model parameters, I could see the outline, but how do i make it visable?
I'm using Inventor 8 Pro |
#20
You have to open the file.
Once it is open drag the little red circle with a white X named END OF PART to the last place on the list. This is located in the browser bar. If you do not see the red circle click view, then toolbars and then click on browser bar. I will try to post the tetra without the end caps... |
#21
we are trying to create a centre goal to test our robot design, but we are having problems with the base couplet (flat surface) and the middle couplet (four attachments)
has anyone been able to create that? FIRST did not provide the design in their manual help on making them would be greatly appreciated CAD, Team 1241 |
#22
Inventor Tetra Assembly Download
Here's the link to our Inventor 30 in. Tetra (http://www.cybersonics.org/cybersoni.../30inTetra.zip)
#23
my version of inventor won't open the tetra file. any chance you can post a step file or anything else so i can use it unitl i get the newest stuff. thanks.
#24
Hey guy the ifirobotics web site has full cad models of the tetras the center goal in step
http://www.ifirobotics.com/first-2005-field-parts.shtml |
| Can someone post this on FIRST q/a | Joe Ross | Electrical | 23 | 16-02-2004 17:28 |
| power connector for 2004 EDU controller | kc8nod | Robotics Education and Curriculum | 6 | 25-11-2003 16:59 |
| Unsafely securing Anderson connector? | Andy A. | Electrical | 20 | 16-04-2003 22:11 |
| 90 degree robot modem connector | archiver | 2001 | 10 | 24-06-2002 00:03 |
| DB15, Male 15 pin connector. | AdamT | Technical Discussion | 8 | 06-02-2002 17:17 |
