Go to Post Yes, it can. You'll have to ask the lawyers around here whether it's legal or not. - Kevin Watson [more]
Unread 11-01-2005, 22:07
Electrical Engineer
Rookie Year: 1995
Re: Are we given sufficient sensors in the kit?
Originally Posted by Nucks
I'm not clear myself what a gyro sensor is, from what I've read and looked through, its some rotation sensor of some sort?
Anyone want to help clarify this for me?
In robotics, it is properly called a yaw rate sensor. It's output is proportional to the velocity if angular rotation rather than the acceleration of other G sensors. This means that there is one less integration required to determine angle versus the double integration of an accelerometer required to give Cartesian coordinate position.
The reason that a YRS give velocity rather than acceleration is that is uses the Coriolis effect in its design.
Having said all this, you have enough info to Google away. If you have more questions after some investigation, fire away...
Mike Betts
As easy as 355/113...
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Usually their called "angular rate sensors". We got one last year from Digi-Key, I think it was the Analog Devices ADXRS150, get the version that has the Evaluation Board with it. It basically registers a voltage change when it undergoes an angular acceleration. If you integrate angular acceleration, you can determine the amount of angle it has turned. This is more useful than dead reckoning or counting wheel / tooth rotations since it depends only on what is happening physically to the robot. Dead reckoning and wheel encoding depends on the wheels not slipping and not hitting anything in its way.
Now has anyone checked to see if the linear accelerometer that is included in the kit have a high enough resolution to be useful? The spec sheet didn't seem to convince me.
Coding CDs in the kit -- What'd you get? elyscape Programming 1 08-01-2005 14:31
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
