Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 10-01-2005, 14:15
Phil Paspalas Phil Paspalas is offline
FRC #1676 (The Pascack Pioneers)
Phil Paspalas is an unknown quantity at this point
Question Tetra Parts
Where can I order the plastic clovers to create more tetras?
Unread 10-01-2005, 14:18
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Tetra Parts
Please search the forums before you post.
Anway here is where you can buy them:
http://www.ifirobotics.com/first-2005-field-parts.shtml
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 11-01-2005, 22:49
jmatocha jmatocha is offline
jmatocha is an unknown quantity at this point
Re: Tetra Parts
Has anyone had any luck finding some material to make their own cloverleaves for the tetras? I've tried two different kinds of plastic I had lying around--one was too flimsy and the second was too brittle and snapped.
Jeff
Unread 11-01-2005, 22:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Tetra Parts
FIRST reccomended using Lexan
[edit] keep in mind there is a difference between Polycarbonate (AKA Lexan) and Acyrlic. Acyrlic may look the same, but it is extremely brittle and will crack and snap
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 01:29
KevinRo KevinRo is offline
Founding Chairman Washington FIRST
AKA: Kevin Ross
FRC #4089 (Stealth)
KevinRo is a name known to allKevinRo is a name known to allKevinRo is a name known to allKevinRo is a name known to allKevinRo is a name known to allKevinRo is a name known to all
Re: Tetra Parts
You should see if you can find LDPE (Low Density Polyethylene) which is what FIRST used. It is a very flexible material, but pretty tough.
I just cut up a whole bunch of the clovers using a power scroll saw. A bandsaw would also do a fine job. Beats the heck out of $4 a pop from IFI.
Kevin
Unread 12-01-2005, 01:39
Andrew Cole Andrew Cole is offline
Machinist
#0294 (Beach Cities Robotics)
Andrew Cole is on a distinguished road
Send a message via AIM to Andrew Cole Send a message via MSN to Andrew Cole Send a message via Yahoo to Andrew Cole
Re: Tetra Parts
I have water-jetted out hundreds of them so if anyone is interested in getting some,probably for free, feel free to contact me. I also put them in the CD-Swap and made some 4-leaf clovers if you want to make the middle goal out of them too.
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Tetra Parts
We made some today, using the leftover 1/4" HDPE from the ramp from two years ago (and last year's platform). I think it will hold up better than the LDPE they use. We've already noticed one of their LDPE clovers starting to rip. Using a good band saw, I was cutting out clovers from the HDPE about one every 2-3 minutes.
Unread 12-01-2005, 01:55
Machinist
Re: Tetra Parts
Thats the same stuff that we used on the water-jet and it made 500 in 30 minutes
Unread 12-01-2005, 01:57
Doug G's Avatar
Coach / Teacher
Re: Tetra Parts
500!! Well, if I had a water jet... Don't get me started!! So I guess your ready to make ~ 40 goals/tetras!
Unread 12-01-2005, 04:47
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
Re: Tetra Parts
I am confused about the parts used to assemble the tetras and goals.
Do all of the goals AND game piece tetras used on the FIRST playing field use the pipe nuts to hold the them together or is this only the goals? Will the game pieces in the competition have PVC end caps, as per the schematics provided for teams to make their own playing fields?
Someone please clarify!
Unread 12-01-2005, 09:01
Twstdkittie's Avatar
Twstdkittie Twstdkittie is offline
You can't kill integrity
AKA: Kittie
#0384
Twstdkittie is on a distinguished road
Send a message via AIM to Twstdkittie
Re: Tetra Parts
Yes, I think they all use the same hardware. As far as I have been led to believe... I think in the actual competition they are as the schematics say.
Rise inside, free your mind
Raise your fist to signify
We stand in defiance of hatred and deception
Parts Swap Jeff Waegelin CD Forum Support 10 30-08-2006 08:23
**FIRST EMAIL**/Missing Parts Orders Due January 13th, 2005! Goobergunch FIRST E-Mail Blast Archive 0 10-01-2005 12:37
PLEASE RESPOND: NRLB & Spare Parts at Nats ngreen Championship Event 12 23-04-2004 16:06
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
