How good is the traction from polyurethane wheels with a durometer number of 90A? Where's a good place to get wide wheels with good traction?
Re: WHeels and traction
If its on the list... they might have something else that they could provide too.. I have the utmost respect for them... To contact them http://www.skywaywheels.com/ check out the website and click on the FIRST area.. it will give you this number (1-800-332-3357) and you can call and they will fax you the price sheet... I talked to a very nice person named Daniel... Make sure you have a fax number ready to give them... I hope this will help you!! Best of luck in the GAME this year!!! |
Thanks, this will help.
You'd definitley have pretty terrible traction with polyurethane durometer 90A. Grooving it might get something back, but it still would definitley be significantly worse than a good rubber tread. It sounds like you might be describing the kit wheels. IIRC, they were about that hard.
Does anyone know the durometer ratings on some tread materials that have worked very well? |
As a general rule of thumb, you can assume things with a lower durometer generally will have better contact and higher friction with the carpeting. That's that! Matt |
Team 100 has used the 6.75"(?) skyway pneumatic knobbies since 2002 with great success.
I would definitely reccomend talking to Skyway to see what theyr'e offering specifically for FIRST use before you look elsewhere. If you have access to a lathe, you can take the kit wheels and lathe the tread material off until it's flat, and then attach belting to them for added traction. Cory |
#7
Some ideas to adjust robot traction are available in the Drivetrain Improvements document found here:
http://www.ifirobotics.com/kitbot.shtml |
#8
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Pneumatic Wheels -> Too Much Traction | OldDan1168 | Technical Discussion | 2 | 24-02-2004 11:28 |
| Q&A Traction Question answer | Cory | Technical Discussion | 4 | 09-01-2003 06:37 |
| traction questions | AlbertW | Rules/Strategy | 2 | 05-01-2003 17:58 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
