Go to Post People misuse GP because they see Dean as some sort of whimsical cross between the Nutty Professor and Mister Rogers and think that FIRST is Disney World and we're all going to happily hold hands around the campfire and sing happy songs all day long. - Koko Ed [more]
Unread 12-01-2005, 12:38
Phil Paspalas Phil Paspalas is offline
FRC #1676 (The Pascack Pioneers)
Phil Paspalas is an unknown quantity at this point
Question WHeels and traction
How good is the traction from polyurethane wheels with a durometer number of 90A? Where's a good place to get wide wheels with good traction?
Unread 12-01-2005, 12:56
Bob Steele's Avatar
AKA: Bob Steele
Re: WHeels and traction
I am not sure what kind of traction you could get from those wheels but we had great success using wheels from Skyway... I am not sure if it has been announced yet but they have several types of wheels with special prices for FIRST members... very durable...reasonably priced...
If its on the list... they might have something else that they could provide too..
I have the utmost respect for them...
To contact them
http://www.skywaywheels.com/
check out the website and click on the FIRST area.. it will give you this number (1-800-332-3357) and you can call and they will fax you the price sheet... I talked to a very nice person named Daniel...
Make sure you have a fax number ready to give them...
I hope this will help you!!
Best of luck in the GAME this year!!!
Unread 12-01-2005, 13:15
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You'd definitley have pretty terrible traction with polyurethane durometer 90A. Grooving it might get something back, but it still would definitley be significantly worse than a good rubber tread. It sounds like you might be describing the kit wheels. IIRC, they were about that hard.
Does anyone know the durometer ratings on some tread materials that have worked very well?
Team 1257
Unread 12-01-2005, 13:36
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Just as a heads up for those of you that may be a little lost, the units of durometer measure the hardness of a material. Hence, something with a durometer rating of 90 will be a hard rubber, as opposed to something in the 30 range which will be much softer. As you go lower, the strength of rubber typically becomes lower as well. Something in the 15 range might be too soft to use as a traction aid.
As a general rule of thumb, you can assume things with a lower durometer generally will have better contact and higher friction with the carpeting.
That's that!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Team 100 has used the 6.75"(?) skyway pneumatic knobbies since 2002 with great success.
I would definitely reccomend talking to Skyway to see what theyr'e offering specifically for FIRST use before you look elsewhere.
If you have access to a lathe, you can take the kit wheels and lathe the tread material off until it's flat, and then attach belting to them for added traction.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 15:05
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Some ideas to adjust robot traction are available in the Drivetrain Improvements document found here:
http://www.ifirobotics.com/kitbot.shtml
Unread 12-01-2005, 15:08
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 12-01-2005, 17:29
Thanks, this will help.
To contact them
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Pneumatic Wheels -> Too Much Traction OldDan1168 Technical Discussion 2 24-02-2004 11:28
Q&A Traction Question answer Cory Technical Discussion 4 09-01-2003 06:37
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
