Go to Post You hang for show; kick for dough. - Travis Hoffman [more]
Unread 12-01-2005, 13:47
Re: Problem with 2004 Robot
If it was working with tether and now it is not, remove the backup battery and try again. If the backup has not been charged in a while, it might be shorted. If the robot functions with the battery removed, suspect a bad battery. NiCads sometimes go reverse voltage when left for some time uncharged/unused. Try a charge cycle and see if it takes a charge before recycling.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
We know, its about time....SOAP Robot Profile 2004 soap108 Scouting 2 06-03-2004 03:31
2004 Robot Controller Default Code Posted Animator Programming 0 09-01-2004 16:00
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
