Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 09-01-2005, 16:04
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
2005 FP Pinion
Does anyone have a tooth count and pitch for the pinion on the 2005 FP motor? Thanks in advance!
Unread 09-01-2005, 16:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 2005 FP Pinion
The manual says it is 21T, not sure on the pitch but in the past they have been 32P.
Unread 09-01-2005, 19:37
Retired -- 2006
Re: 2005 FP Pinion
Sanddrag,
Where does it say 21T in the manual? I haven't seemed to find that.
Unread 09-01-2005, 20:04
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: 2005 FP Pinion
Ours is a 14 tooth, 32 pitch
www.179swampthing.org
Unread 10-01-2005, 09:06
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
Re: 2005 FP Pinion
Dan is correct. Everyone should have a 14 tooth, 32 Diametral Pitch gear on the FP motor. THe documentation on the list of kit parts says 21 teeth and it is wrong.
-Paul
Unread 12-01-2005, 13:25
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Re: 2005 FP Pinion
Anyone have an idea of how this gear is attached to the shaft - and any success removing it safely. What methods have been used?
Thanks in Advance
Ken
Team 476
6th year rookie
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Unread 12-01-2005, 13:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 2005 FP Pinion
Thanks in Advance
Ken
Team 476
6th year rookie
The best way to do it would be with an arbor press.
You *COULD* attempt to cut a wedge out of it with a dremel and remove it that way. I don't think this is a good method at all, but some teams swear it works. You have to be incredibly careful to make sure that you dont cut into the shaft, or get shavings into the internals of the motor.
Also, I believe Paul posted a drawing for a gear puller that can be made with a mill, on here last year sometime.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 13:42
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 2005 FP Pinion
How would you press, or pull for that matter, it off? I can't see how you can support the shaft properly.
Team 1257
Unread 12-01-2005, 13:50
UCGL_Guy's Avatar
AKA: Ken YorK
Re: 2005 FP Pinion
First let me say we haven't received our kit yet so I haven't seen this year's motors. Our machinist in just quickly looking at some from prior years said they look like they are "glued" to the shafts. has anyone actually removed these gears from the shafts this year?
Keep the cards and letters coming.
KY
Ken York
Will Rogers
Unread 12-01-2005, 13:53
Cory's Avatar
AKA: Cory McBride
Re: 2005 FP Pinion
Cut a slot in a plate and slide it on the shaft so it's supporting the gear.
2001-2004: Team 100
Unread 12-01-2005, 15:05
UCGL_Guy's Avatar
AKA: Ken YorK
Re: 2005 FP Pinion
thanks for all the help- got an answer from the source.
press it off
Ken York
Will Rogers
Unread 12-01-2005, 19:57
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Re: 2005 FP Pinion
-Paul
I am confused.
I just counted the teeth on our F-P motor from this year's kit and it has 15 teeth, not 14. I counted it 4 times and had 2 other people count it.
Can anybody physically confirm the number of teeth on their motor?
Thanks
Matt B.
Unread 12-01-2005, 21:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 2005 FP Pinion
Originally Posted by MattB703
I am confused.
Thanks
Matt B.
This is bad... ...will you please post a picture of you motor -- especially the sticker on the side, a close up of the gear would be good too.
If you have 15T, then F-P has provided and/or FIRST shipped a mixed lot. Without actually taking the motor of the transmission it is close to impossible to tell the difference. Even off the transmission it can be very hard to make the ID.
Paul Copioli and I can tell you that the folks that service these transmissions for F-P (in the Detroit area in is McNichols Electric just down the block for Beaumont Hospital on 13 Mile) have absolutely no idea which motor is which, in fact, the guy told me he goes SOLELY by the # of teeth on the motor pinion when he sells a motor. Paul and I both told him that this is not really an adequate method, but I don't think we made a dent.
If I were you, I would a stall the motor (for a short period of time) at 0.8 volts or so and accurately measure the voltage accross the motor and the current. If the current is not about 10 Amps at 0.8V (i.e. the Resistance should be 0.08 Ohms per the spec) ,you have confirmation that you have a different motor than the rest of us.
How many other teams have counted the pinion teeth carefully? Any more 15's out there?
Joe J.
Team #88, TJ2
Unread 12-01-2005, 21:46
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 2005 FP Pinion
This is worse: 188 has counted teeth, and the number is 13. I've just got off the phone with those involved, and they had separate people count it (twice!). For reference, the identifying marks on the motor are as follows:
74550-0642
TD034701
Unread 12-01-2005, 22:11
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: 2005 FP Pinion
Thanks in Advance
Ken
Team 476
6th year rookie
We had good luck last year on the hardened gears on the drill motors with a cold chisel a block of steel and a ball peen hammer. I would test this on a softer gear for a motor that you are not going to use or a spare. I just put the chisel (a small one, that didn't fit to the bottom between the teeth,and not too wide) between two teeth with a helper holding the motor and the block of steel under the gear, and gave it a good whack. It split the gear almost down the center and the remainder came off with a gentle tug with fingers. I don't know if this is an excepted method, but it did more for us.
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Your Thoughts on the 2005 Championship Eligibility Criteria! dez250 Championship Event 57 10-09-2004 14:59
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
