Go to Post This year it is what it is and, at some point, we will all find out what that is, specifically. - JaneYoung [more]
Unread 12-01-2005, 11:23
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
Spike Connection
I'm sorry but i couldn't find the answer in my search so i'll ask a question i'm sure others have asked before.
How do I control the Spike ?
I could only make a motor turn one way or stop turning at all. how do i turn it in the other way?
do I connect the spike to the RC using a PWM output or a digital output?
how do i control it through the software?
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
Unread 12-01-2005, 11:29
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Spike Connection
From www.ifirobotics.com
Spike - User's Guide (.pdf)
Spike - Installation Info (.pdf)
Spike - FAQ
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 12-01-2005, 11:34
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
First of all, read the above noted documents posted by Katie.
Now... you need to make sure that you are not trying to control any of the CIM, FP, Globe or the Taigene motors using the spike relays. The are not designed to handle the current draw.
Second, if you are looking to turn on/off (at full speed) the Mabuchi motor, then you could utilize a relay. If however you are trying to vary the speed of the motor, you have to use a speed controller.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 12-01-2005, 12:14
Electrical Engineer
Rookie Year: 1995
Both Bob and Katie's posts are correct. I will try to elaborate.
The spike must be connected to a relay output on your robot controller.
Modify the default RC code to control the spike. As an example, the following code will cause a motor that is connected to a Spike that is connected to relay output 3 on the RC to run backwards:
	relay3_fwd = 0;
	relay3_rev = 1;
Be sure to read the documentation Katie posted and follow directions for wiring precisely!
Good luck!
Mike Betts
As easy as 355/113...
Unread 12-01-2005, 13:59
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Yeah, we were connecting it to the wrong output
Thanks guys it works great now
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
window motor connection albertgates General Forum 1 12-02-2003 17:18
