Go to Post People should listen to this Andy Baker character, he seems like a smart guy... - Karthik [more]
Unread 12-01-2005, 16:02
buss buss is offline
AKA: Steven
FRC #0180 (S.P.A.M. Robotics)
buss has a spectacular aura aboutbuss has a spectacular aura about
Send a message via AIM to buss
Turrets
For any teams that have made some sort of turret, how did you do it? I was thinking of getting a cheap bicycle wheel and modifying it. Any ideas?
Steven Buss
"Far and away the best prize that life offers is the chance to work hard at work worth doing."
-- Teddy Roosevelt
Unread 12-01-2005, 16:11
wojahoitz's Avatar
wojahoitz wojahoitz is offline
AKA: Nick De Haas
#0058 (Riot Crew)
wojahoitz will become famous soon enoughwojahoitz will become famous soon enough
Send a message via AIM to wojahoitz
Re: Turrets
Could you elaborate on "turret" I am not sure I understand what you are trying to get at.
The Riot Crew
On Field Coach - 2003-2007
Captain - 2004-2007
nick.dehaas@gmail.com
Unread 12-01-2005, 16:19
AKA: Steven
Re: Turrets
Picture a tank turret, i just want something I can rotate with a simple motor and gear.
Steven Buss
-- Teddy Roosevelt
Unread 12-01-2005, 16:34
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Re: Turrets
We used chain and sprockets with a motor (attached to one sprocket) to power the turret system that we had. The sprockets were mounted horizontally inside of a rectangular box, with one sprocket mounted to something like a platform so that the box as a whole would rotate.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 12-01-2005, 16:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Turrets
I know team 294 Beach Cities had a very nice turret design last year but I didn't get a chance to see it in action. Also if I recall correctly, 980 Thunderbots had a turret as well but I may be mistaken.
Unread 12-01-2005, 19:21
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Turrets
you can mount a central spindle and then make a disk of aluminum in the diameter you want to mount the tower on. To make the disk get a sheet of 1/4 " thick aluminum and lay out the circle. Install a bearing in the center to thread on the spindle. Carefully drill out the perimeter to make sprocket teeth . We have used a sheet of teflon under the disk to allow it to slide. A motor mounted nearby and a sprocket drive the chaiin that turns the whole thing. We did this in our champion 2000 bot and in last year's 2004 big arm machine.
Good luck.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 12-01-2005, 23:52
Re: Turrets
There are several sources for a "lazy susan" bearing. You can get them in various diameters up to 12 or 15 inches and they are only about 1/4" high. I bought several at work (I think from McMaster) sandwiched between two pieces of plywood with a pipe flange on one. This makes an excellent cable reel holder when pulling cables. I know they are made to hold up to several hundred pounds. Check the specs when you order one.
