Go to Post This is what happens when Engineers try to design a sport. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2005, 22:02
wmurphy wmurphy is offline
#1529 (Cyber Cardinals)
wmurphy is an unknown quantity at this point
Kit of Parts - Sprocket Spacers? and Transmission Lubrication?
Q1. In order to correctly mount the sprockets on the motor shafts, there appears to be a "woodruff key" and maybe a "spacer"? or something that slides over the shaft? For some reason, our guys can't seem to find them in the kit of parts. Are we out in left field on this one? How do we actually mount the sprockets (2 wheel drive version) to the transmissions?
Q2. What type (and how much) of lubrication is best for the transmission gears?
Thanks,
Murf
Rookie Team 1529
"MURF"
Unread 11-01-2005, 22:20
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
Re: Kit of Parts - Sprocket Spacers? and Transmission Lubrication?
we are cutting small bits of pvc for ours... we dont have any metal tube atm, but we will probably cut soem metal spacers.
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
Unread 11-01-2005, 23:10
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Thanks,
Murf
Rookie Team 1529
I'm sure other people will have different opinions, but I'd just use a small amount of any kind of grease you have around, like car front suspension grease, wheel bearing grease, or whatever. There would be a little less power loss at high speed using oil or very "light" grease, but the difference would be very small. The power loss from "shearing" the lubricant is much smaller with these Atwood motor applications than with the higher rpm drill and FP motor applications. Unless you run your robot where it is really sandy, you should get a season's use from the kit transmissions with about any kind of lubricant.
Team 1062, The Storm, 2003
Unread 11-01-2005, 23:32
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I would reccomend just a drop of *light* oil (model train) on the bearings, bearings can freeze. As for the gears, you are probably ok, but, we usually use just a touch of synthetic white grease, fairly light.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-01-2005, 00:03
Confucius37 Confucius37 is offline
El Prez/El Driver
AKA: Vic
#0599 (RoboDox)
Confucius37 is an unknown quantity at this point
Right, like white lithium grease, much lighter than the heavy wheel bearing grease and can aso be found at any auto parts store.
Unread 12-01-2005, 18:04
Thanks,
Murf
Rookie Team 1529
I believe the PVC spacers are used on the 5" Axle Bolts. Those are not the "spacers" that I was referring to. What I was really trying to ask about was the spacers or collets or collars??? that appear to slide over the woodruff keys on the transmission motor shafts. In other words, how do we actually mount the sprockets (2 wheel drive version) to the transmission shafts? Could we be missing these parts? We have the two sprockets that afix to the motor shafts, as well as the two woodruff keys, but there appears to be something else we need? Thanks, Murf
"MURF"
Unread 12-01-2005, 18:10
Pi Is Exactly 3's Avatar
Pi Is Exactly 3 Pi Is Exactly 3 is offline
AKA: Alex... aka... Zog
#1474 (Tewksbury Titans)
Pi Is Exactly 3 will become famous soon enough
Send a message via AIM to Pi Is Exactly 3
Are you talking about the black spacer? Because if you are, then my team is also missing that piece.
Vice President
Head of Mechanical
Coach / Strategist
Visit Our Website!
Unread 12-01-2005, 19:57
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Neither of you is missing a part.
This component was NOT included in the KOP and must be fabricated.
http://www.ifirobotics.com/forum/viewtopic.php?t=122
JV
Unread 12-01-2005, 21:49
Thanks! <By the way, I realized later that I kept describing the location of the "mystery part" incorrectly - it's NOT on the actual motor shaft, but rather the spindle protruding from the transmission housing.> Thanks for not making me feel like a dummy!
"MURF"
Unread 12-01-2005, 21:57
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
adding to the discussion, what has everyone been using for axles? i know they didnt come in the kit.
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 13-01-2005, 01:09
JVN JVN is offline
@JohnVNeun
The chassis is designed such that teams may use a 3/8" Bolt as a wheel axle.
