Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
Unread 12-01-2005, 16:42
Chris Reynolds's Avatar
Chris Reynolds Chris Reynolds is offline
**Insert Custom Title Here**
None #1259 (Paradigm Shift)
Chris Reynolds will become famous soon enoughChris Reynolds will become famous soon enough
Send a message via AIM to Chris Reynolds
Concealing The Battery???
Doe syour robot's battery have to be concealed? or do just the wires have to be?
Thanks!
~Chris Reynolds, and Team 1259
I've got 50 GMAIL invites left. Email me if you want one. Skaferreal@gmail.com
AWARDS
2004 Spirit Award (Midwest)
2004 Best Rookie Seed (4th place) (Midwest)
2005 Imagery Award (Midwest)
Unread 12-01-2005, 17:00
occra 23.
AKA: ryo
None #1481
Re: Concealing The Battery???
what do you mean concealed? no you dont have to have it covered as to be not seeable. and it has to be secured securely. and the terminals must be electrical taped or shrinkwrapped. as long as it is safe, there arent very many rules concerning how the battery is placed in the robot if there are any.
Unread 12-01-2005, 17:06
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Chris,
try to be VERY SPECIFIC in your question.
I believe you are inferring about "concealment" of the battery during SHIPPING, versus the battery location during the tournament.
The rule book is very explicit about placing the battery in a "covered compartment" during shipping with proper labels. See rule book 6.2
http://www2.usfirst.org/2005comp/Sec...sportation.pdf
Unread 12-01-2005, 17:50
What I meant to say was... Does your robot's battery have to be completely covered when you are competing? If we want it to be on the exterior (for whatever reason) does it have to have a box around it?
Thanks!
AWARDS
Unread 12-01-2005, 18:06
Andy A. Andy A. is offline
Getting old
FRC #0095
There is no rule that specifically says your battery must be concealed (or, not one that I could find).
However, the forces involved when two robots collide are probably high enough to damage or crack the battery case. This would be a very hazardous and bad situation.
For that reason, I would strongly advise you to place your battery in such a way as if another robot runs into you, it would be difficult/impossible for it to make direct contact with your battery. It is not necessary to have the battery in a 'battery box', simply that it is not exposed to the playing field.
-Andy A.
Unread 12-01-2005, 18:48
copertop's Avatar
copertop copertop is offline
Team President
AKA: JD
FRC #0578 (Blue Lightning)
copertop is an unknown quantity at this point
Send a message via AIM to copertop
If you really have a need to put the battery on the outside of your robot then the best idea would probably to put a piece of lexan or some type of durable material between the hostile world and your Robot heart... if you crack that baby you are done for... so is the playing field.... toodles!
Team 578:
Second place in Pittsburg Regional 2004
Semi-Finalists in Buckeye Regional 2004
Winners of the controls award in 2004 at Buckeye
Who would like to design and impletment an Uber fan?
I DO!!!!!!!
And image!
<image code yo> opps </image code yo>
Programmer error!
Unread 12-01-2005, 19:16
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Also, make sure that an appendage can't just come in and hook the terminals out.. We had that happen one match two years ago, not pretty.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
First of all, no - there's no rule that says your battery had to be concealed when it's on the robot.
If, for some reason, you are thinking about putting the battery on the outside of the robot ... I'd think again. Like Andy A. said, one hard hit and it could get cracked or fall off. Placing the battery inside the robot chassis does take up a lot of space, but it protects the battery a heck of a lot better (assuming it's strapped down and all - not just thrown in there.)
This is what 93 has been doing for as long as I've been associated with the team. Check this out:
That's the bare-bones of TOBOR V (2002.) The battery sits, on it's side, on a piece of polycarb, swiss-cheesed for weight. Two small pieces of polycarb are glued on the first piece, so they sit on either side of the battery, when it's in. There is *just* enough room for the battery to fit in between these pieces ... it's a pretty snug fit. To keep everything in place, a single buckle-strap goes from "top to bottom" and is tightened, once the buckle is ... buckled. Of course, once the battery is connected, the connection is zip-tied for security.
It's simple, easy to make, pretty light-weight, and your battery won't fall out!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 12-01-2005, 19:40
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Question Re: Concealing The Battery???
i guess this thread would be a good place for this question, what do we do about old batteries this year? It says we need to ship them in the original containers, is there anything to do about this if you don't have the original case?
Unread 12-01-2005, 19:46
Lisa Perez's Avatar
All teams are to use the batteries that came in the kit of parts - and these batteries have their original cases.
Unread 12-01-2005, 19:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Not only that, but by putting it on the inside of the bot on the very bottom you help lower your CG, which is going to be huge in this game
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 21:33
i'm talking about extra batteries saved up from years past
Unread 12-01-2005, 23:30
Thanks!
Chris,
The battery needs to be protected from damage due to collision, damage due to shorting of the terminals to each other or other robots, and falling out. No Battery=No Play. Many years ago a team built a box for the battery and used it at the end of a swinging arm for counter weight, it was a cool idea and well designed...but robots didn't push as much as this game will. Six to eight feet of #6 spells reduced voltage available for drive motors.
Lastly, regaardless of what your decision, the battery must fit inside the size box even if it is left on the cart while weighing in. You run the risk of a picky inspector saying the battery is unsafe.(me included)
Unread 13-01-2005, 17:16
dhitchco's Avatar
Awards/Photo/Video &quot;wizard&quot;
AKA: Doug Hitchcock
Per rule <R03> in section 5.3, an externally-mounted battery could very easily be considered to be a "protrusion" by the judges.
Yes, they're really looking at it fromthe perspective of "spears", "forks" and "offensive" safety hazards, but a battery (unprotected) would likely raise some serious issues.
However, don't forget that weigh-in this year EXCLUDES the battery, so it must be easily removable. See <R08> under section 5.3.2.2.
Unread 14-01-2005, 07:12
I think that is a little bit of a stretch. This rule pertains to parts that hang over the field border and pose a hazard to staff or competitors.
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
