Go to Post STEM is the new cool, STEM is the new fun, but nobody said STEM is the new easy. - Taylor [more]
Unread 12-01-2005, 16:31
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
eNc is an unknown quantity at this point
Send a message via MSN to eNc
Rookie Pneumatics
Hi everyone, I was just wondering if we could get some advice/insight into how we would go about making a pneumatic telescoping arm. Our team has no experienc in this feild and any help would be much appreciated.
-- eNc^
Last edited by Madison : 12-01-2005 at 17:29. Reason: Corrected spelling in title.
Unread 12-01-2005, 21:08
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: Rookie Pneumatics
First search, search,
Second, in general, telescoping is much easier in concept than in practice,
Finally, if you are bound and determined, send me an e-mail at jwriteclub@gmail.com
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-01-2005, 21:43
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Telescoping is a pretty easy concept, but can be tricky to implement.
Last year, we telescoped our arm to gain the height to grab the pull up bar.
This was done by two lengths of square tubing, where one fit inside the other.
Then, a pneumatic piston was attached to the inner tube, and the outer tube, and then extended, pushing the inner tube up out of the larger outside tube, and resulting in a telescoping action.
I don't have any good pics of the mechanism we used, but can take one at the meeting when I get a chance and send them to you, or put them in our gallery if you would like.
Unread 13-01-2005, 08:38
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
yes some picture would be much appreciated... and yes i will search lol
-- eNc^
Unread 13-01-2005, 15:13
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
First, you should print off the 2005 pneumatics manual and look at the examples. Understand the difference between a single and double solenoid before you start proposing ideas. The solenoid should be positioned as close to the cylinder as possible for the most efficient use of your air.
The biggest problem I see with using pneumatics this year is the air. Even if you can afford to have an on board compressor without going over weight, you still will have trouble with air deficiency because the pneumatic cylinders use a lot of air very quickly.
Just some things to consider.
Unread 14-01-2005, 12:25
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
Umm so can you get back to me with those pics if possible?
-- Thanks
-- eNc^
Unread 01-02-2005, 20:31
Han Tzu's Avatar
Han Tzu Han Tzu is offline
Team Stander: AKA The Human Playa!
AKA: Metal Master
#0617 (Springers)
Han Tzu can only hope to improve
Sometimes it is not best to use pneumatics for telescoping arms. A rack and pinion, cable and pulley, and of course pneumatics are all devices you can use to do some sort of system like that. The hard part is figuring out what kind of hook-up you want to use with that device. For any of the above, you could directly hook it to the bottom of the shaft, or top if it suits you, use a wire that acts on a system of pulleys if you're spanning a large distance, or you can use a slider and gravity. Whichever you think your team will be able to build and handle is up to you.
Pneumatics is a wonderful thing for rookie teams who dont have a lot of experience. Their limited range of motion are offset by the fact that they are simple to assemble, program and are very good at working (and by working I mean not breaking).
Rookie 2005 Nats Qualification? Alexander McGee Championship Event 2 27-10-2004 10:14
A ? about NASA grants computhief263 General Forum 18 29-03-2004 13:35
Rookie Regionals rachakate Regional Competitions 5 24-03-2004 00:01
I want to have a rookie nationals! Tton Championship Event 5 23-04-2003 14:46
