Go to Post Less playing to the camera, more talking about cool FIRST stuff please. - Cuog [more]
Unread 12-01-2005, 21:07
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
Using 6 motors in a drive system?
If you were to put 6 motors in a robot just to drive it around for the 2 minutes and 15 seconds would you have enough battery for 1) The whole round and 2) For other things 3) A compressor ???
Team 1089 alumni coach.
Unread 12-01-2005, 21:15
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Using 6 motors in a drive system?
We did last year. You must have an efficient drive system and it also depends on how much you use other motors and how much your compressor runs.
We do not stop playing because we grow old;
we grow old because we stop playing.
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Uh, depends on a lot of factors. Here is a tip: Battery capacity is measured in Amp-Hours. So if a battery is rated at 10 Amp-hours (that figure it entirely ficticious) this means you could draw 10 amps for an hour, or one amp for 10 hours (although this is not a perfect relationship, because batteries have internal resistances). You'll need to lookup the datasheets on everything you intend to put on the bot and make reasonable estimates for how much they will draw in the application you intend to use them in.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 12-01-2005, 21:19
Electrical Engineer
Rookie Year: 1995
You have an 18 AH battery. That is 60*18=1080 amp*minutes. For a 2.25 minute match, you can draw 1080/2.25=480 amps. You have a circuit breaker which will limit you to less than that.
Answer: Yes.
Mike Betts
As easy as 355/113...
Unread 12-01-2005, 21:21
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I think that the exide batteries are 18 amp-hours
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-01-2005, 22:03
It is important to note that when a battery is specified at 18 AH, that is for the current draw over a long period of time. For our battery, it was for 20 hours. When you draw more current, the battery has a lower capacity.
It's defintely worth your while to look at the battery's data sheet: http://www2.usfirst.org/2005comp/Specs/batex.pdf
For our battery it is 18AH over 20hrs. Over 1 hour, it is only 10.8 hr. Looking at the discharge characteristics, At approximately 50 amps, it will last between 5 and 8 minutes. At 100-120 amps, you are probably getting close to the 2 minute 15 second match length.
Also note that the 120 amp circuit breaker doesn't trip as soon as it reaches 120 amps. The data sheet is here: http://www2.usfirst.org/2004comp/Spe...it_Breaker.pdf
The circuit breaker will actually allow 200+ amps for 10-20 seconds. It will also allow at least 140 amps for the full 2 minute match.
With those two pieces of information, I have no doubt that it is possible to completely drain the battery in 2 minutes and 15 seconds without tripping the main 120 amp circuit breaker.
Unread 12-01-2005, 22:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I've personally verified this through calculations and empirical observation; Woburn Robotics has used variations of 6-motor drivetrains for the last three years, with occasionally stunning results.
In 2002, the 60 A circuit breaker was a major liability; we removed the two drill motors at our second event (and used the CIMs and Johnson F-Ps), after several breaker-throwing episodes. (Incidentally, we needed a 2-speed, badly, that year.)
In 2003 with a single-speed transmission, all but the most hard-fought matches were handled easily, with no breaker issues (on the more rugged 120 A main breaker); however, matches with more than a minute of consistent pushing would reduce the robot to 6 or 7 V under load, and disable the robot controller. We once managed to push one reasonably powerful opponent up and over the ramp, from our end zone to theirs, before running out of juice, and ourselves getting pushed most of the way back. (Consider that my only driving mistake.... ) The breaker never tripped. For high-speed driving (and the robot was geared rather high), it was very driveable, and extremely responsive.
In 2004, the robot was given a 2-speed gearbox, and though (in hindsight), the gear ratios were too far apart, it demonstrated superb speed and pushing power, while never encountering a power consumption issue. (Batteries were, however, religiously changed after every match; there was no desire to find ourselves short on power.)
The bottom line: it's never been easier to do it, because of the four CIMs, and, if you don't want to put those motors elsewhere, it's a nice place to make use of them. Remember, if you have trouble, you can always remove the offending motors!
Unread 12-01-2005, 23:49
Alumni
AKA: Erik Cokeley
I would do this if I had an extra 8 hours and all the information put into 1 packet but maybe after build season I will. For rite now I think we will just do 4 motor drive system.
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
