Go to Post Think like a criminal, and write the law to foil them! - Tristan Lall [more]
Unread 12-01-2005, 16:30
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Code Download via Serial Issue
Interesting problem I seem to have here. We're trying to download some code with IFI loader to the old controller and I'm getting instant "Failed to open port" errors. Any ideas? I've searched quite a bit and nothing seems to match this exactly. Tried all the obvious things... I think, such as switching COM ports and checking the connection...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 12-01-2005, 17:56
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Re: Code Download via Serial Issue
Hi,
I have one PC that will not load any of the .hex files from this year into either the new or old RC without creating code errors. It will load last year's .hex file. (I have tried numerous reboots, reconnects, power up/down, etc).
This same stubborn PC, when using the 'printf' function, will only print the first letter to the terminal window when using IFI Loader...it leaves out the rest.
However, I have no problem doing this from the other PCs in our lab. Go figure...
I can't explain this...not smart enough. Have you tried doing this from another PC?
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
Unread 12-01-2005, 20:53
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Two thoughts.
1) My understanding is that there is a firmware difference between the 2004 and 2005 controller.
2) Try the PIC1618 loader I posted on one of the other threads. "just search my posts). It can be a bit tricky, but it is the full microchip loader, as opposed to the adulterated IFI loader.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-01-2005, 20:56
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Phrontist:
It might be due to the firmware on the old controller. I know it shouldn't make much difference, but maybe code written on MPLAB 7.00 only works with the new firmware. Anywho, if you haven't updated, you should do so anyways. Might help, might not, but it can't hurt.
Besides that, I don't know what else it could be.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 12-01-2005, 21:01
phrontist's Avatar
Proto-Engineer
Originally Posted by Anthony Kesich
Phrontist:
-Tony K
Good thinking, that's probably it...
Unread 12-01-2005, 21:02
CJO's Avatar
CJO CJO is offline
Also, check out your install, there should be several .dll files installed, if not, re-install.
Unread 12-01-2005, 22:57
I assume you've also made sure nothing else is trying to use the serial port? The palm hotsync program is a common culprit.
Unread 14-01-2005, 21:51
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Last year I had trouble downloading hex code using IFILoader. It would fail about 4 times out of 5. It turns out that the serial port on my Dell Latitude CPi didn't really quite work at 115Kbaud. I borrowed an IBM laptop and that worked fine, but I couldn't keep it.
My solution was to purchase a USB to serial converter (BAFO 810):
http://www.pcwebshopper.com/iobf810.html
See this thread on the IFI site:
http://www.ifirobotics.com/forum/vie...highlight=bafo
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 14-01-2005, 22:12
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I've been caught way too many times trying to use the IFI Loader while the CMUCam2 GUI was open =P...
-SlimBoJones...
Unread 08-02-2005, 17:32
phrontist's Avatar
Proto-Engineer
I'm really at a loss here. I get these errors instantly (see first post) regardless of wether the serial cable is connected. This leads me to believe the serial port is not configured at all, but I can't seem to figure out how to go about doing that in XP.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
