Go to Post Flattery will get you everywhere. - nuggetsyl [more]
Unread 12-01-2005, 23:01
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Ink n' Paint Texture Question
I was just wondering if there was any way to use current standard textures in 3DS Max through Ink n' Paint. For example, say I want to apply a floor tile texture, but I want it to look cel shaded through an Ink n' Paint texture - can this be done?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 12-01-2005, 23:25
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: Ink n' Paint Texture Question
I'm pretty sure it can be done. I'm trying to do it right now and I'll get back to you on that.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 13-01-2005, 00:05
Eric Rowe
OK, it can be done. Here's how:
  1. Open the material editor by pressing M.
  2. Select the Ink 'n Paint Material by clicking the standard, then Ink 'n Paint from the choices.
  3. Under the Paint Controls rollout, where it says "lighted," you'll notice theres a choice to select a map which is currently set as none. Open that up and select tiles from the list.
  4. Test render to make sure you got it. (It might not look like Ink 'n Paint unless you have shadows covering it).
A couple notes. By unchecking the check box under where it says "shaded," you have an option to apply a completely different material using the same technique. Also, you might want to apply a slight bump using the same tile material to make the grout look more realistic.
Attached is the test I did for experimentation. I have the tiles and then just reversed the colors of the tiles for the shadowing and added a slight bump based on the tiles. PM me if you want the file. I'll try to keep it for a couple days. Hope that helps.
Eric Rowe | Alumn
Unread 13-01-2005, 08:27
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
are you just doing it for a tiled floor or are you doing it as something else??
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 13-01-2005, 15:13
Well, a tiled floor might be one thing, but I'm talking about all the default textures 3DS Max comes with - can you run each one through Ink n' Paint??
Unread 13-01-2005, 16:06
Eric Rowe
I misread your original post. It is possible to make different materials as a subset of Ink 'n Paint, but you cannot use the default materials. You can however, use the default maps to make your own Ink 'n Paint materials. To do this, use the same method I used to make the tiled floor. (I'm guessing that bitmaps will not work, unless you have a cell shaded bitmap. The shading one the actual object will be cell shaded though.)
Eric Rowe | Alumn
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
