Go to Post Competition and inspiration go hand in hand. Those who inspire will be pushed to do it again and again by those who see this as a healthy competition. Those who are inspired will compete to be an inspiration to others. You can have your cake (competition) and eat it (inspire) too. - Andy Baker [more]
  #31   Spotlight this post!
Unread 11-01-2005, 02:25
Tracker of LTU Tracker of LTU is offline
Tracker of LTU is an unknown quantity at this point
Wink Re: Designs that would never work...
Make a robot with two turrets, and put massive expanding fans on it. (bed sheet idea). Just put all the motors in the bottom of your robot with cables and lead screws to move the turrets. Driver then moves the robot between 2 goals and spreads the fans over the goals. Driver then parks and takes over a fan, and 2nd driver controls the other. With a 10' diameter, you don't need to worry about moving the robot. This results in blocking a center path, the center goal, and a side goal. Problem is tipping....
  #32   Spotlight this post!
Unread 11-01-2005, 08:37
n0cturnalxb n0cturnalxb is offline
AKA: Shirley
#1159 (Ramona Rampage)
n0cturnalxb will become famous soon enoughn0cturnalxb will become famous soon enough
Send a message via AIM to n0cturnalxb Send a message via MSN to n0cturnalxb
Anyone fora flying robot?
zip ties and duct tape: the answer to all of life's problems
  #33   Spotlight this post!
Unread 11-01-2005, 08:42
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
didn't a team have a hoverbot in '02 ? I wouldn't argue that flying is out of the question lol (so you have no traction, but it definately would make for a "like a bat out of h***" autonomous, going for the center goal and capping).
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
  #34   Spotlight this post!
Unread 11-01-2005, 10:24
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
I someone could get enough lift for the necessary controls, battery, and a tetra I would be greatly inspired. I think it may be possible, but I do not have the knowledge, time, or resources to figure out if it is even possible.
See you in DC!
  #35   Spotlight this post!
Unread 11-01-2005, 10:37
ZoNeGuY's Avatar
ZoNeGuY ZoNeGuY is offline
Public Relations Head
AKA: Adam Bowers
#1458
Team Role: Communications
ZoNeGuY is on a distinguished road
Send a message via AIM to ZoNeGuY
Its not impossible, but in the requirements yeah its pretty much impossible.
I dont think it would be a bad idea though, it could be useful to have such a speedy bot.
  #36   Spotlight this post!
Unread 11-01-2005, 10:56
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
It would be easy to build a hover bot, powering it would be the problem. There is no way the compressor could produce a high enough volume of air to make it hover, and arent there rules against building your own compressor?
  #37   Spotlight this post!
Unread 11-01-2005, 13:11
Another way to go about actually doing it is to build a fan, though as pointed out earlier in a previous thread, something of that nature would probably be considered a saftety hazard (very sharp fan blades kinda thing). Still...talk about a crowd pleaser! lol
  #38   Spotlight this post!
Unread 11-01-2005, 13:31
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Originally Posted by Justin
For what it is worth,
Never say never...that was a rule my old team use to live by. We would always start the season by considering that without fail in FIRST for ever design you come up with you will probably see it on a robot that season. It happened to me year after year. So Never say Never ;-)
Good Luck all!!
Justin
I can remember thinking in 2001, "we should push the goals up the ramp from the floor" or "we should build a ramp bot so other teams can get on the ramp." After some deliberation, my team decided that the pusher bot would be impossible to build strong enough, and the ramp bot would require too much reliance on alliance partners, and therefore be ineffective. The national champions and national finalists (Beatty and Wildstang, respectively) built robots with those features. So much for impossible and ineffective, eh?
Jeff Waegelin
  #39   Spotlight this post!
Unread 11-01-2005, 19:13
Steve P Steve P is offline
#0521 (L33t Cr3w)
Team Role: Driver
Steve P is infamous around these parts
Send a message via AIM to Steve P
Since stack attack, during the kickoff video for that game there was one robot that was at the top of the ramp, had like a 20 foot long arm that took a box off the enemy's side and put it on thier own stack all the while on the platform. Ever since then I wanted a 22 foot long tesalating arm that bends in 3 places and is fully rotational.
  #40   Spotlight this post!
Unread 11-01-2005, 19:59
übernerd's Avatar
übernerd übernerd is offline
übernerd is an unknown quantity at this point
i think the best bot design would somehow involve a death ray...though it wouldnt be graciuos professionalism, it would work
  #41   Spotlight this post!
Unread 11-01-2005, 20:49
Specialized's Avatar
Specialized Specialized is offline
Student-Parent Liason/I make stuff
AKA: Chris Riedinger
FRC #0195 (CyberKnights)
Specialized is a jewel in the roughSpecialized is a jewel in the roughSpecialized is a jewel in the rough
Send a message via AIM to Specialized
the perfect robot would be one that is effecient, fast, BUT MOST IMPORTANT OF ALL: SIMPLE!!!!!!!!!
Thankyou!
  #42   Spotlight this post!
Unread 13-01-2005, 00:25
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
I can think of all the fun things you could do with flying robots. Though the judges would never let it pass, think about what would happen if it suddenly went haywire and went flying into the audience...
But then that got me thinking about something else. I started thinking about blimps and then about other inflatables. You know those inflatable life rafts? The ones that you pull a cord and then some super pressurized air inflates the raft in seconds? It sure would be fun to just strap one of those to the top of a robot, drive it to the other side in autonomous mode and then just pull the rip cord...
The funny thing would be if one of the enemy bots wasn't stuck on their side and then charges the thing with a pointy arm pointed straight at the inflated raft . POW!
I'm really getting carried away aren't I? I need to get some sleep...
G'Night!
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
  #43   Spotlight this post!
Unread 13-01-2005, 00:34
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by dlavery
The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance.
Oh, come on, Dave... there's no way you're gonna fold that 747 into a 28x38x60 box.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #44   Spotlight this post!
Unread 13-01-2005, 08:38
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
he he you guys are nuts.
last year my 1st idea was to make a expanding net that cough all the balls when they dropped. i was told it to be imposable, yet surely enuf there was a team that could catch and dispense every last one of them
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
  #45   Spotlight this post!
Unread 13-01-2005, 09:09
robolemur1236's Avatar
robolemur1236 robolemur1236 is offline
robolemur1236 can only hope to improve
lets see...
you can have a giant conveyer-belt bot that can load up every last tetra from human and auto stations, then pulls arms out of the ether to drop them on goals
a bot that climbs the player station, shoots a zipline to the other side of the field, then traverses that line back and forth to drop tetras?
arr, weight limits
being requiring of an interesting team name/mascot/motto that is appropriately geeky and at the same time pleasing to the ear.
How do the servos work? tml240 Motors 25 18-02-2004 07:47
Pneumatic Layout (Does it work?) Matt Fultz Pneumatics 14 04-02-2004 14:56
Ideas that don't work. CanisLupis547 General Forum 6 13-01-2004 19:07
Bumper Sticker Designs Robby O Chit-Chat 11 15-07-2001 11:37
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
