Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 13-01-2005, 08:51
Andy120369693 Andy120369693 is offline
#0549 (Devil Dawgs)
Andy120369693 is an unknown quantity at this point
Send a message via AIM to Andy120369693 Send a message via Yahoo to Andy120369693
Reducing the weight of the KitBot
Does anyone know of any ideas on how to lose weight on this year's drive train?? What does everyone think of the weight, with the weight of the gear box and the chassie it weighs almost 30 lbs already. Is there anyone who knows if there is a way to get the gear box to run w/ only one motor? The gear box alone, w/ 2 motors, weighs almost 9 lbs.
Unread 13-01-2005, 08:55
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
Re: Weight loss
ther are instructions included to only use one motor
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
Unread 13-01-2005, 08:58
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Weight loss
I'm assuming you mean the drive train that came with the kit. Simple, drill some holes (in everything possible) until you A) Lose enough weight or B) Think by drilling more you'll lose structural integrity.
The best way may be to create your own drive train.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 13-01-2005, 10:43
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Weight loss
I'd like to comment on the KOP transmissions, and put a new perspective on them. We built our own transmissions last year, for a single speed, single motor (CIM) drivetrain. We had to do some design work, purchase gears/shafts/material, and then spent about 1 week machining all the pieces. In the end, we had an efficient, smooth, very effective gearbox, which was flawless throughout a years worth of competition. But, it heavily taxed our team resources, and delayed our autonomous testing for over a week.
This year, we've compared the KOP gearboxes with the ones we built last year. These offer a similar gear ratio, the ability to mount one or two motors, and can be assembled in one hours time with absolutely no machining. Also, these gearboxes weight about 1 pound more (each) than our custom-made, heavily machined gearboxes. To me, it's a no-brainer. These KOP gearboxes are wonderful, and with a minimum of machining time can be kept to the same weight as our previous gearboxes. Not to mention, we'll have a driving chassis by the end of the weekend. Way to go Paul on a great addition!
Bengineer
Team 228
Unread 13-01-2005, 11:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Weight loss
Not true, they were designed to use either one or two motors. The video shown at kickoff specifically showed two motors being installed.
As for weight reduction, you can drill holes or mill pockets into the gears, as well as drilling holes into the sprockets.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-01-2005, 13:35
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Weight loss
I think what he meant to say was exactly what you said, that you don't have to use all 4 cims to power your drive train, that you have the option to choose a 2 motor per transmission set-up or only one motor per transmission set-up.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 13-01-2005, 13:49
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Weight loss
I must whole heartedly agree.
If you're going to be using a single speed drive train, you need to strongly justify NOT using these. Every team only has so many person-hours and engineering talent at their disposal.
FIRST isn't all about making everything from scratch. In the real world, very little usually is.
On a side note.. something to think about. I've seen a few people suggest lightening the gear cases via drilling holes or something of that nature. I haven't given it a ton of thought, but initially, the case itself is very light. Having a mostly sealed gearbox seems like a good idea to me.
I've never heard someone say, "I'm really glad I had this gear box wide open. The dirt and metal chips really improved our performance."
I've definitely heard the opposite, "Why didn't we just cover this gear box with a sheet of .010" polycarbonate to keep all the junk out?
You might want to consider drilling a couple of 3/8" holes above the gears you use to spray a little lubricant, but outside of that... you really can't beat it.
My $.02,
MJA
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 13-01-2005, 14:17
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Weight loss
My $.02,
MJA
We are leaning in the direction of using the provided gear boxes as well. The thought we had was to cut a window for inpection and lube, replacing the cut away with polycarbonate keeping out dirt and tetras.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 22-01-2005, 18:24
GMorin GMorin is offline
FRC #0228 (Team Gus)
GMorin will become famous soon enoughGMorin will become famous soon enough
Re: Reducing the weight of the KitBot
We were able to cut the weight of EACH gear by up to 50% or so.
The gears have very large diameter hubs. I made an arbor with a key slot to hold the gears on a lathe and turned the diameter of the hubs.
On the thicker hub-less gears, trepanning the faces of the gears works well.
In addition to the lathe work, all gears had holes drilled into them. If you have a Bridgeport mill, this job is a lot easier.
Unread 22-01-2005, 18:40
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Re: Weight loss
I would be very careful about attempting this.
I'm not a M.E. but you maybe ordering a new KOP tranny very soon.
Try reducing weight in other areas.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Weight Michael Leicht General Forum 43 16-01-2005 10:09
Weight Issues KathieK General Forum 1 05-11-2004 18:03
reducing gear box weight mickjagger Technical Discussion 16 23-01-2003 20:35
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
