Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 13-01-2005, 10:45
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Re: How to cut flat sided holes for Globe and Door motor
Originally Posted by Max Lobovsky
Why not use a trantorque or some other clamp for the Globe also? On a related note, do either motors shafts need support if using them for chain?
I've used trantorques on both in the past. Yes, the globe shaft needs support. It cannot handle sideloads.
Unread 13-01-2005, 13:57
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
neither can the mabuchi motor (look in the FIRST guidelines and they highlight the globe and the mabuchi on this). Motors in general don't like side loads so I would be supporting all of your motors so that they do not experience this.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 13-01-2005, 14:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What we have done for both the Globe and Van Door motors in the past was this. Take a piece of steel shaft say 1/2 inch di. Face the end of it in a lathe and then drill a hole into the end of it that is just slightly larger than the di. of the round part on the end of the motor shaft. Then take the shaft and lay it in a vise on a mill. Tighten it snug but don't smash it. Then mill a slot right into the end of it. Slide it over your motor and use a shaft collar to clamp it on.
