Go to Post "Needless to say, my Roomba will be making my toast from now on" -Colbert - artK [more]
Unread 13-01-2005, 12:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: THE Fisher-Price Motor Spec Sheet
Woburn has a box of F-P gearboxes dating back to the late 90s. There are at least four different kinds in there, and (except for colour--some are white, most are black), they all look identical from the outside. With the issues with differently-sized F-P pinions this year, you should definitely disassemble them and count teeth, if ratio is critical.
Unread 13-01-2005, 12:28
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally Posted by Andy Baker
So... what we will probably do is run this thing at a maximum of 9.6 volts, as the engineer from Mabuchi suggested.
I like your solution better than Dr. Joe's. But please tell: Are you proposing a EE solution that steps down the voltage outboard of the Victor, or a software solution where the PWM signal is limited to a precalculated value, so that the effective voltage at the motor is 9.6v? (Or something else? Will the Victors work properly if you limit their input voltage?)
Unread 13-01-2005, 13:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by gwross
I like your solution better than Dr. Joe's. But please tell: Are you proposing a EE solution that steps down the voltage outboard of the Victor, or a software solution where the PWM signal is limited to a precalculated value, so that the effective voltage at the motor is 9.6v? (Or something else? Will the Victors work if you limit their input voltage?)
Do you object to the complexity of the algorithm or to proposed operation? I think several teams did something very like this to stay right on the edge of the 120 Amp breaker from tripping in the 2002 Season. I don't think it is that complicated and I think the performance of the motor would be significantly better than the performance via limiting to 9.6V. 9.6V would still very easily fry this motor under some conditions while at other times (at the beginning of the match for example) it would limit the output needlessly.
As to whether Andy is proposing putting 9.6V on the input side of the Victor or limiting it in software (via max. & min PWM outputs), I don't know how you could actually put 9.6V on the input side of the Victor within the rules of FIRST.
Joe J.
Team #88, TJ2
Unread 13-01-2005, 13:12
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Joe J.
I was just thinking that we would do it in software, and never run this motor over 80% of full power.
AB
Electrical Engineer
Rookie Year: 1995
Joe J.
Limiting the PWM in software is just as effective as limiting the input power to the Victor as far as the motor is concerned. It has the added benefit of being within the rules as well. A PWM limit would be my mitigation choice.
Mike Betts
As easy as 355/113...
Unread 13-01-2005, 13:21
Electrical Engineer
Rookie Year: 1995
AB
Andy,
Verify your PWM limit via DVM. Refer to this post: http://www.chiefdelphi.com/forums/sh...168#post310168 and ignore most of the follow on discussion. It is not important why this non-linearity happens... We must deal with it.
Mike Betts
Unread 15-01-2005, 20:19
n0t4g4iN's Avatar
n0t4g4iN n0t4g4iN is offline
FRC #0011
n0t4g4iN is an unknown quantity at this point
I am just wondering your file say that the motors model number is RS-550PF-8021 while on the first website in there 2005 Specification Sheets section they say the model number for the motor is RS-545SH-2485. Can you clear up this misunderstanding I am having about what these model number mean and why they are different. Thanks
Unread 16-01-2005, 11:43
President, VEX Robotics, Inc.
There are two different types of Mabuchi motors in the kit: the two Fisher-Price motors (Mabuchi part number RS-550PF-8021), and the one
small Mabuchi motor provided directly by Mabuchi (part number RS-545SH-2485). Two separate spec sheets for two different motors, both are in the kit.
-Paul
Unread 17-01-2005, 12:46
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
scottm87 is on a distinguished road
6) after the temp rises above a certain number, THEN and only then, I would limit POWER INPUT to the amount that I can dissipate at the current speed
Couldn't you just measure the temperature of the motor? (some kind of thermistor or temperature sensor...) Given that it takes only one digital or analog input (depending on how much circuitry and what sensor) and skips 5 steps (and the associated error), that would be my solution. You may have to scale it considering you are measuring the temperature on the outside, and the temperature on the inside is proportionally hotter.
Although it might be useful to have the current for the motors measured anyways...
- Scott
Unread 17-01-2005, 16:27
AKA: Dr. Joe
FRC #0088 (TJ2)
- Scott
The only reason I think a model for the temp rise would be better than a thermistor or some other measurement technique is that the temp you really care about is the temp of the armature. This is not so easy to get a real temperature for because it spins. The delay between what you can measure and what the true temp of the armature is could be significant.
This brings up another possible measurement scheme. If you know current and voltage AND speed, you can infer temperature. Basically, you know voltage and speed so you know, theoretically, what your current SHOULD be if the armature were room temp. To the extent that the current is different (in this case lower) than predicted, it must be that the resistance of the motor has increased due to hotter wire in the armature.
Since the resistance of copper wire is pretty well understood, you should be able to get a pretty good estimate of the temperature of the armature using this method, assuming that the current dynamics are fast with respect to the motor dynamics which is typically a pretty good assumption.
Again, this may sound complicated, but once it is worked out, it runs in the background more or less for free, keeping your motors at their peak without allowing them to overheat. I suppose with a bit of tuning, a generic code could be used by any team for any motor that they measure current and speed.
Once I am king and have minions at my disposal, I will be sure to put a few of them on this task ;-)
Joe J.
Team #88, TJ2
Unread 17-01-2005, 19:20
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Joe,
I don't know if you can get a good view of the armature, but an inferred thermometer may work. With the motor spinning I think you would get the average of the whole armature, and not just the windings. But if you stop it you could get a peak temp reading. Some IR thermometers have a wide measuring spot like a 1/2 inch or more closeup.
Unread 17-01-2005, 21:14
AKA: Dr. Joe
FRC #0088 (TJ2)
Counting teeth?
I still have not touched a 2005 Fisher Price motor/transmission (hopefully someone will get one down from the school to work tomorrow).
But... ...I am trying to answer a question tonight. Has anyone actually verified the total gear ratio on this year's F-P?
Share your data and I will share my toot counts tomorrow.
Thanks.
Joe J.
Team #88, TJ2
Unread 17-01-2005, 23:12
Here are the ratios for the gearbox with the 13 tooth motor pinion:
1st stage: 72/13 ~ 5.4
2nd stage: 79/25 = 3.16
3rd stage: 62/19 ~ 3.26
4th stage: 38/12 ~ 3.17
Total gear ratio = 58,776/325 ~ 180.849:1
So 24,000/180.849 = 132.7 RPM at free speed assuming no gearbox friction slowing motor down.
-Paul
Unread 17-01-2005, 23:30
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Eeeek! The FIRST Tips and Guidelines sheet was wrong. Well that means we've got at least one wasted sprocket...
Team 1257
Unread 18-01-2005, 00:54
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I have posted a question on the FIRST Q&A, asking if they will verify/validate the data shown in the Guidelines document. Let's see what they say...
-dave
Fisher Price Motor Into Drill Gearbox Chris Technical Discussion 11 21-04-2004 09:09
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
Multiple Fisher Price Motors? authgeek1218 Motors 5 10-01-2003 10:48
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
