Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Unread 13-01-2005, 00:37
eR1c599 eR1c599 is offline
#0599 (Robodox)
eR1c599 is an unknown quantity at this point
Hows your electronics board?
I know there is a thread already here, but i would like to see drawings and/or schematics of what other teams are doing for their electronics board. I did search so i have like two schematics that i found. I would like to see more.
Thanks,
Eric
Team 599
P.S. This is made also to help other teams to see what people are doing, and help the rookie teams because they probably will want help with this part of the build very soon.
Unread 13-01-2005, 07:25
Re: Hows your electronics board?
Eric,
I know this sounds bad but we don't make an electronics board. In order to fit everything in with mechanical systems, we will distribute the parts around the robot for best weight distribution and ease of replacement. We do work with a couple of standard rules though.
1) Wiring from battery to connector to main breaker to fuse panel is as short as it can be.
2) Victors are generally placed close to the motor they control when practical.
3) All connections are crimped, then soldered, then heatshrink is applied.
4) Wiring in general takes the shortest path.
5) All wiring, all controls, all motors, and all PWM cables are color coded.
6) All wiring is secured in place.
7) All wiring is inspected by several team members before power is applied in breaker out.
8) Breakers are added to test individual circuits.
Unread 13-01-2005, 11:19
SkiRacer SkiRacer is offline
Measure once, cut twice
AKA: Andrew
FRC #1676 (Pi-Oneers)
SkiRacer is an unknown quantity at this point
Send a message via AIM to SkiRacer
Exclamation Re: Hows your electronics board?
Originally Posted by Al Skierkiewicz
Eric,
Doesn't That cause a Problem when you need to acess the electronics, if they are scattered throughout the robot?
Unread 13-01-2005, 11:53
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
As long as you place them in an area that is still accessible i dont see why wildstangs approach would be bad. One of the biggest mistakes i ever made on a robot was placing all of the electronics in 2 areas of the robot with 2 shelves in each area, replacing anything or getting to anything on the bottom shelf was a nightmare, i think the best rule of thumb for electronics is accesibility, followed closely by organization. If you cant get to a problem or identify where the problem is, then your in for a real nightmare when something goes wrong.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 13-01-2005, 12:53
It would not be my first choice in design to spread things out, but the tradeoff we make is to maximize power to electrical components and to fit into all the spaces left by mechanical. It is absolutely necessary that the RC, Victors and Spikes be available for replacment, motors are usually part of mechanical assemblies so that any problem in a subsystem cause the entire system to be replaced and analyzed. I cannot take full credit for the color scheme. When the red motor stops turning, you look to the red speed controller, red PWM, red PWM output on the RC, red circuit breaker, red power wiring, etc. It makes trouble shooting the fastest part of pit work, and allows us to easily diagnose an electrical failure from a mechanical one. With this method, repairs can easily be accomplished between rounds, even in finals.
Unread 14-01-2005, 00:51
#0599 (Robodox)
Ok sorry my bad, i didnt want to create a discussion whether a board or not is better. i would like to see peoples electrical system schematics. Like there overall wiring. Stuff like that.
Thanks,
Eric
599
Unread 14-01-2005, 10:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks,
Eric
Team 599
http://www.swarren.ca/Build2004photo.../IMG_0820.html
We used an inside-out approach last year, and will probably do the same this year. Power comes into the middle, and is distributed outwards. You can basically guess where all the eventual wire runs go. from the picture. This layout was done by Team188 members Carol Huang (Grade 11) and Honson Lam (Grade 9). Steve W originally posted about this picture in a separate thread.
Our layout was used for an electrical demonstration for rookie teams last year, and also won Team 736's award for "Neatest Electrical" at the Canadian Regional.
-SlimBoJones...
Unread 14-01-2005, 11:02
AKA: Mr. Lim
A quick addendum:
The robot controller was placed on a 2nd level above the board in the picture. We ran the PWM cables out from the RC and straight down into their respective components on the level below.
-SlimBoJones.
Unread 14-01-2005, 11:09
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
We're waiting until finalization of our overall design until we work on our control board setup. Last year we had a LOT of trouble with the stupid PWM cables coming loose. We're most likely gonna set the board up in a fashion to minimize that effect.
Unread 14-01-2005, 12:52
copertop's Avatar
copertop copertop is offline
Team President
AKA: JD
FRC #0578 (Blue Lightning)
copertop is an unknown quantity at this point
Send a message via AIM to copertop
Another thing that you should worry abotu when you mount your electronics.... The circuit breaker panel should be mounted in a vertical position so that if your robot is hit the breakers don't "accidentally" reset themselves... This isn't all that important for motors but your robot controller may be reset and you could lose valueable seconds when you need them most! check out this thread.... It happened to our robot the year before i joined. http://www.chiefdelphi.com/forums/sh...ad.php?t=19340
Team 578:
Second place in Pittsburg Regional 2004
Semi-Finalists in Buckeye Regional 2004
Winners of the controls award in 2004 at Buckeye
Who would like to design and impletment an Uber fan?
I DO!!!!!!!
And image!
<image code yo> opps </image code yo>
Programmer error!
Unread 14-01-2005, 13:23
Copertop,
I have not had a team report repeatable problems with the circuit breakers we use. There have been production defects from time to time. There has also been defects caused by high current operation due to mechanical designs. The post you refer to indicates some extreme handling, not the type you are likely to get with a robot collision. I don't consider this a problem. Be careful when reading old posts, they often have been resolved and answered.
Unread 14-01-2005, 15:42
copertop's Avatar
Team President
AKA: JD
That is true... But the animation this year had robots "strategically touching" eachother... I think that in the competetition this year there will be a great deal more contact than of previous years. Just my thoughts on the subject. I am working on finding the drawing we have of our electronics form last year... IT was this really nice image... done in autocad i think? I will chack with Jake.. Toodels
Team 578:
I DO!!!!!!!
And image!
Programmer error!
Unread 15-01-2005, 23:10
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
We called our elecronics board a "poo poo platter". That has changed this year. We are now sticking all of our electronics in a 12inx18in box. It is a REAL tight fit for 7 of the Victors, 2 spikes, the computer, and breaker panel.
Team 302
Unread 16-01-2005, 00:06
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
We always make an electronics board, that way all of our electronics are in one location and easily accessible. We also always make sure that the wiring on the board is organized, and every wire / PWM is labeled as to where it goes / what it is for. We just started drawing some electrical diagrams today .
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 16-01-2005, 00:23
D.Stephenson's Avatar
D.Stephenson D.Stephenson is offline
AKA: Denise
FRC #0871 (West Islip Robotechs)
D.Stephenson is on a distinguished road
Send a message via AIM to D.Stephenson
we started our electrical board today, we mount everything on one side of the board and run the wires under the board to reach all the connections they need to reach, we started doing that in 2003 and having all the wires under the board helped us alot
Team 871-Since 2002
pic: Jesuit 1097 Electronics Board CD47-Bot Robot Showcase 8 01-03-2004 12:35
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
