Go to Post And Dave...should I borrow someone's hair dryer from here in case the NASA truck needs some de-icing again this year? - Billfred [more]
Unread 13-01-2005, 13:18
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Viewing Angle of Camera
Does anyone have a spec or done an experiement to know the maximum viewing angle of the CMUcam2 (left/right viewing angle and up/down viewing angle)?
I looked but didn't find anything in the documentation. Sorry if I missed it.
Joe J.
Team #88, TJ2
Unread 13-01-2005, 13:27
Electrical Engineer
Rookie Year: 1995
Re: Viewing Angle of Camera
Joe,
As usual, you and I are heading down the same path. When the camera sights two vision tetras, the "center" of the combination will be tracked...
An interesting problem. N'est-ce pas?
Mike Betts
As easy as 355/113...
Unread 13-01-2005, 13:36
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I do not know the angle offhand, but it is possible to close down the window size to reduce the view area.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 13-01-2005, 13:51
AKA: Dr. Joe
FRC #0088 (TJ2)
While I know I must be heading someplace good if Betts is leading the way, in this case, I think he is out there blazing a path while I have not yet packed my bags.
My reason for asking was more along the lines of "How much of the field can I see?" rather than "How can I keep from seeing too much?"
In this case, software is no help. It can reduce my field of vision by ignoring pixels but it can't increase it by adding pixels to the side of a CCD array.
So... ...my question remains.
Anybody know and willing to tell us?
Joe J.
Team #88, TJ2
Unread 13-01-2005, 22:06
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Joe J.
I measured it tonight: about 60 degrees field of view.
Pete Kieselbach
Unread 13-01-2005, 22:20
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Nice. Data you guys. I asked a simliar question before but it was about the actual range of the cmu2. How far can that camera see before the object it out of sight. I looled thru the manual but could not find anything on the distances. Thanks everyone.
Unread 14-01-2005, 09:37
It's a camera. It doesn't have a range limit. How far away it can detect something would depend on the size and brightness of what it's looking at. I am certain it would have no problems seeing an object nearly a hundred million miles distant, if that object were sufficiently large and well lit.
Unread 14-01-2005, 11:09
AKA: Dr. Joe
FRC #0088 (TJ2)
60 Degrees both in the UP/DOWN and LEFT/RIGHT direction?
Joe J.
Team #88, TJ2
Unread 14-01-2005, 13:25
petek's Avatar
What would Dave do?
Joe J.
I measured just left/right.
Pete Kieselbach
Unread 14-01-2005, 13:44
Joe J.
Joe,
The lens is listed as a 4.9 mm, F2.8 lens(I had to search but found it on one of the CMUII sites). The target area is 4.86 mm x 3.64 mm. for a diagonal of nearly 1/4", the listed specification for this device. Plug in the numbers for the diagonal and the focal length and it comes out to about 60 degrees. Since the aspect ratio for this camera is 4:3, the horizontal look angle is less than 60 degrees and the vertical is even smaller. This of course is in a perfect world and the lens in this camera is not self compensating for focus, distance to pickup, etc. so the FOV (field of view) will vary from camera to camera. According to my lens calculator (fudging for the tiny pickup area, my calc only goes down to 1/2") FOV (horizontal) is 22-25 ft. at 20 ft from the camera.
Unread 14-01-2005, 14:11
petek's Avatar
What would Dave do?
Originally Posted by Al Skierkiewicz
Joe,
...According to my lens calculator (fudging for the tiny pickup area, my calc only goes down to 1/2") FOV (horizontal) is 22-25 ft. at 20 ft from the camera.
That correllates well with my measurement of about 9 ft (left:right) at a radius of 9 ft. If the aspect ratio is 4:3, then you should expect about 60 degrees horizontally x 45 degrees vertically. I wasn't trying to measure the FOV to high accuracy - figure 9 ft. +/- 3 in. - but somehow I doubt that FOV accuracy is going to be that critical a factor with these cameras...
Pete Kieselbach
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Calc. Triangle Angle or Side Based on Ellipses? indieFan Math and Science 1 07-06-2004 21:25
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Webcast camera angle... Joe Johnson Regional Competitions 13 11-03-2002 16:35
