Go to Post Engineering is a fabulous background for many careers. - dtengineering [more]
Unread 10-01-2005, 17:26
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
Strange CMUCam Image
We're experimenting with the CMUCam and have everything hooked up. There are no problems other than that the image recieved by the GUI app is completely messed up. We have gotten it to show the basic shape of an opject held in front of it, but no real image like that in the getting started guide. Any ideas?
Unread 10-01-2005, 17:33
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Strange CMUCam Image
sorry to say, but ours works fine, really good quality too, i suggest that you report that your cam is defective ASAP.
don't mess with it, just tell them it's not in working condition, and ask for a replacement (also i think it's obvious that you should mention that you are not responsible for the fault!)
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 12-01-2005, 23:54
pickle's Avatar
pickle pickle is offline
Talking vegtable
AKA: Jeremy
#1296 (Full Metal Jackets)
pickle is on a distinguished road
Send a message via AIM to pickle
oooh! I had this same problem, check the baud rate and stuff on your serial port, go into the device manager and find the entry for com devices, then right click on the com port and go to properties, then under I think the second tab (sorry, not on my windows machine atm), make sure those setting correspond with the ones they give you on like the third page of the start here manual. this fixed my problems, the com port defaults are probably NOT what CMU cam requires
2004 Rookie Inspiration Award winner - Midwest Regional
2004 Autodesk Visualization Award winner - Lone Star Regional
2004 Quarterfinalist - Lone Star Regional
2005 Team Spirit Award - Lone Star Regional
Unread 12-01-2005, 23:55
I thought I had tried this, but hearing the same problem from someone else — I'm trying again. Thanks.
Last edited by Sidney San Martín : 12-01-2005 at 23:56. Reason: Strange formatting
Unread 13-01-2005, 00:15
Bharat Nain's Avatar
From the troubleshooting part of the manual:
 I get wavy lines or a distorted black and white image when I call
 dumpframe:
 This is most likely due to power. Make sure that you have a high enough voltage
 and that you are getting a clean signal. Running the camera off of fresh batteries
 not an AC adaptor) is a good way to test if this is the problem.
I don't know if that helps. I havent been able to get our teams camera up and running yet.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 13-01-2005, 00:46
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Ours is working fine, but we cannot connect when it is also connected to the robot, so make sure something like this is not happening. Also, as mentioned before, check all power cables and make sure your baud rate is set right. If you have one, try testing the camera through a usb-serial adapter. While I have had problems with these when programming the robot before, we used another team members laptop equipped with an adapter today for the GUI, and it worked fine (although it was not COM1, rather COM4 but this probably varies). If this way of communication works, you will know that your standard serial connection is malfunctioning or not set properly.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
Unread 13-01-2005, 03:06
pickle's Avatar
Talking vegtable
AKA: Jeremy
Ah yes, I also changed the battery, both of which may help. Run a volt meter to it and make sure the battery is giving you at least 7 volts. (The backup battery of course)
Unread 13-01-2005, 12:57
sybert1ger's Avatar
sybert1ger sybert1ger is offline
The Systems Engineer
AKA: JR
FRC #0078 (AIR Strike)
sybert1ger will become famous soon enough
We weren't having quite the same image problem but our images were very hard to distinguish.
We found that you can change the camera resolution to high if you go to the config tab in the software. I hope that helps.
Unread 13-01-2005, 13:39
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
From what I can tell, the CMU cam software is really cobbled together, I am hoping we can get the source, and try to fix it.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 13-01-2005, 13:43
ubik ubik is offline
antisocial devil's advocate
AKA: Matt Kovacs
#0931 (Perpetual Chaos)
ubik is an unknown quantity at this point
when my teammates and I hooked the camera up for the first time, everything worked, but the image was really blurry. we found out that the camera has a manual focus, as in you just twist the camera lens. I don't know what kind of object you're trying to "see" there, however, and with those lines there I'm not really sure that this will help at all. but, if you run out of options, you can try to change it and see if it helps.
There are some forms of insanity which, driven to an ultimate expression, can become the new models of sanity. - BuSab Manual
Hey! That reminds me of the last three weeks before ship date!
Unread 13-01-2005, 13:46
Electrical Engineer
Rookie Year: 1995
You recieved it when you downloaded CMUcam2GUI.zip in the src subdirectory.
I have not had any problems with it as long as you stop one task before starting another...
Mike Betts
As easy as 355/113...
Unread 13-01-2005, 14:05
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
exactly the most annoying part! plus, if you press stop twice, it will crash.
-Paraphrasing JFK
Unread 13-01-2005, 15:06
fixermark fixermark is offline
FIRST Robotics Alumnus
AKA: Mark T. Tomczak
None #0422 (Maggie Walker Mech Techs)
fixermark is a name known to allfixermark is a name known to allfixermark is a name known to allfixermark is a name known to allfixermark is a name known to allfixermark is a name known to all
Send a message via AIM to fixermark
I think this is one of those times where an open source advocate somewhere mutters "Well, you've got the source..."
Seriously, though, if the double-press issue (or any other GUI glitch) is giving you a hassle, it shouldn't be too hard to fix. As a hack, you could probably throw a little finite state machine into the GUI interface software that either hides or ignores the stop button if the system is not in a state where stopping makes sense.
As a student at CMU, I wish I could say "That bug shouldn't be there," but I've worked on too many projects like this to say that with a straight face . Not having been involved with the CMUCam project, my guess would be that it sounds like the hardware people assumed the software people wouldn't do something "obviously incorrect," and the software people assumed the hardware people wouldn't allow the camera to choke on "meaningless but well-formed input." Control system design teams, take note: there's a lesson here...
As for me personally, given that the CMU cam is pretty awesome, and has the distinct advantage over other solutions of existing right now, I'm willing to forgive the design team for missing the "totally awesome" mark. If anyone decides to tidy up the software, share the fixes with the rest of us!
Best of luck to everyone,
Mark
Unread 13-01-2005, 16:28
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
if i get around to it, and if i understand the code, and if i learn how to execute java code, i promise to share the results with the community
-Paraphrasing JFK
Unread 13-01-2005, 17:48
viewtyjoe viewtyjoe is offline
Code Monkey
AKA: Nathaniel Davis
viewtyjoe is an unknown quantity at this point
Send a message via AIM to viewtyjoe
We still have yet to experience problems with the camera, aside from the fact that our color recognition is tenuous at best. And from what I've been seeing, we're not the only ones experiencing this problem. At least we still have decent motion detection, once you increase the threshold. We still haven't looked at the robot code implementing the camera yet, so we have no idea how that will run.
New cool image generator Elgin Clock Computer Graphics 13 03-11-2004 20:10
Image Capture for Real Player? indieFan Chit-Chat 12 22-06-2004 22:22
Getting an image from a website Raven_Writer Website Design/Showcase 17 09-06-2004 11:39
extra image discussion text rbayer CD Forum Support 15 06-05-2004 19:04
