Go to Post Ask the right questions and you can get the right answers. - Chief Hedgehog [more]
Unread 12-01-2005, 22:00
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
How to cut flat sided holes for Globe and Door motor
How have teams cut holes in their sprockets and gears to interface with the flat sided shafts of the Globe and sliding door motor? Even with mill, there is no way to cut the edge between the curved and flat parts of the motor. Leave that edge with an oversize fillet? Would a circumscribed rectangle work? Is there any way to do a sloppy job if you can't get to a mill?
Team 1257
Unread 12-01-2005, 22:17
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: How to cut flat sided holes for Globe and Door motor
circumscribed rectangles work just fine. the flat part of the shaft is what holds the assembly from spinning. if you have a cnc than you can mill the pocket to the correct shape. i've done it both ways with absolutely no trouble.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 12-01-2005, 22:20
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
use a waterjet, a laser, a small endmill, a file, anything can do it
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
The Machine shop that donated work for our team last year did it with a wire burner. He was able to cut the proper hole for a globe shaft in a 9 tooth #25 stainless sprocket, that started with a 1/4" bore. We had no issues with that sprocket hope to visit him again and get another one or two made for this year.
Unread 13-01-2005, 09:59
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
For the Power Sliding Door motor we have had very good success with an 11mm Trantorque.
They run about $30 from McMaster, but we love them. No changes to the motor (which is good if you burn one up and have to switch) and a simple hole (22.5mm if I recall) in the gear you want to attach to the motor.
As to the Double D on the Globe, I know some teams have modified a standard round broach to put in the flats. I THINK the Globe has a 3/8 round shaft with flats, so if you buy a 3/8 broach and grind in the flats, you should be all set. I have not done this myself, but have heard good reports.
Joe J.
Team #88, TJ2
Unread 13-01-2005, 10:40
Fold em oval!
Why not use a trantorque or some other clamp for the Globe also? On a related note, do either motors shafts need support if using them for chain?
Team 1257
Unread 13-01-2005, 10:45
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
I've used trantorques on both in the past. Yes, the globe shaft needs support. It cannot handle sideloads.
Unread 13-01-2005, 13:57
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
neither can the mabuchi motor (look in the FIRST guidelines and they highlight the globe and the mabuchi on this). Motors in general don't like side loads so I would be supporting all of your motors so that they do not experience this.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 13-01-2005, 14:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What we have done for both the Globe and Van Door motors in the past was this. Take a piece of steel shaft say 1/2 inch di. Face the end of it in a lathe and then drill a hole into the end of it that is just slightly larger than the di. of the round part on the end of the motor shaft. Then take the shaft and lay it in a vise on a mill. Tighten it snug but don't smash it. Then mill a slot right into the end of it. Slide it over your motor and use a shaft collar to clamp it on.
