Go to Post I trust in Martus. - Petey [more]
Unread 13-01-2005, 23:01
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
pic: Possible Team 114 Drive Component
2004 - Drive Train- 2 Awards | 2005 - Drive Train/ Driver/ Team Captian - 3 Awards | 2006 - Mentor- 8 Awards
Unread 13-01-2005, 23:03
Pshyco's Avatar
Pshyco Pshyco is offline
Bulider
AKA: Phecda Louie
#1241 (Theory6)
Team Role: Student
Pshyco is on a distinguished road
Send a message via MSN to Pshyco
Re: pic: Possible Team 114 Drive Component
WOW... ...thats really nice compared to ours, even though we are a second year team hehehe
Unread 13-01-2005, 23:13
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
First of all, I do want to point out that the person who designed this has put a lot of time into it. It is a very nice concept. but there are few things that caught my eyes and can be modified to make it better (this is where i need the engineers and mentors to correct me if i am wrong).
1) the Drive shaft on the wheel? is that going through 3 bearings (looks like there are 3 plates). if it is, thats BAD. you want to fit everything between two plates. (I can be wrong about this one, I was taught to never put 3 bearings on the same shaft)
2) looks like, the front, back and top sides itselves have 36 hex head screws. Dont you think it can be reduced down? maybe use only 16 screws? why not take a few aluminum L brackets (8 should be good) which are 1/8th thick and use them to hold all sides together (2 on each side).
The overall concept is great. A few tweaking might help you to perfect the design. If you are seeking for help, dont hesitate to ask me or any mentors. Also, if you do want to take a look at a good crab module, you might want to look at "The Navigators (team 79)" crab drive from 2003.
Good luck...
-Arefin.
Unread 13-01-2005, 23:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Good luck...
-Arefin.
Or you could check out any of them by Wildstang... I hear theyre kinda good
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2005, 08:33
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Though it can be very hard to do for a compact drive train like this, in general, you want to isolate your precision parts from your main structural parts that should be bending to some degree. The only real way to do that for a crab drive is having one or two gearboxes for the whole robot chained to each module with power transferred coaxially.
Of course, this is purely a very general design rule and because a bigger concern than weight efficiency is often ease of manufacturing, you may have no choice.
Team 1257
Unread 14-01-2005, 10:36
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
My 0.2c
the design looks nice, but there are a bit too many bolts on there. The builder could consider welding three sides together and have one side connected by bolts, because holes reduce strength and bolts can be heavy.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 14-01-2005, 10:44
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
How many of those gearboxes do you plan on including on your chassis? And what's the gear ratio? (I'm having difficulty seeing through the holes in the side)
Unread 14-01-2005, 11:32
Cory's Avatar
AKA: Cory McBride
Odds are four, since it's a swerve drive.
2001-2004: Team 100
Unread 14-01-2005, 11:33
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
Nice design. I agree that it would be better to reduce the number of bollts. Weld anything you can if you have the resources. What rpm do you have coming out of the gearbox?
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 14-01-2005, 14:15
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
I'm curious as to why you choose such a large wheel diameter? If you went to a smaller wheel, you could make a considerably more compact, and lighter gearbox. Its not as if their are any field features that require a large wheel either.
Also, with a smaller wheel, you don't need as much reduction in the gearbox itself, creating a more even more compact and lighter gearbox.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 14-01-2005, 16:30
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Actually, there are some design considerations if you are planning on driving over the aproximately 1.6" high bar that makes up the base of the goals. One of the things that I have been taught to do is to give your wheel a diameter that is at least three times the height of the object you want to climb over for best traction. You could technically do this with a diameter that is two times greater than (but not equal to) the height of the object you want to climb over, but for best results, the object you want to drive over should be 1/3 the height of your wheels. (Please correct me if I am wrong about this)
But back to your design, it looks like you have a good start, but I can't really offer any excellent input as I am also in the learning stages myself.
Florida Institute of Technology
Ocean Engineering, '12
Unread 14-01-2005, 23:44
James114's Avatar
Thanks for the feed back, and as most of you have pointed out there are way too many bolts and I agree, so that problem is being addressed. The heights of the wheels are such that if it does drive over the field Goal, it will be able to get back over. The gear reduction for each module is 18:1, the output shaft RPM is around 230. There will be 4 modules, like Cory said.
If you have any ideas for improvements, just drop me a message.
Unread 14-01-2005, 23:50
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
It's a really nice design, but what about weight? For 4 of these and the arm, and also size of it so that it can be able to move between the middle larger tetras? Those are just some things that might become problems, but you probably have it all planned out. But overall, that's a really cool omni drive system.
Unread 15-01-2005, 01:38
Cory's Avatar
AKA: Cory McBride
*nitpick* It's not an omni, or holonomic drive. It's swerve/crab. The difference between the two is that while with swerve you can translate in any direction without changing the orientation of the robot, with a holonomic drive, you can not only translate, but rotate the robot around itself at the same time.
2001-2004: Team 100
Unread 15-01-2005, 12:27
James114's Avatar
Well since weight is always an issue in the end, I did my best to keep the weight of each swerve module as light as possible. According to the weight calculator in Inventor each module will weigh around 8 pounds.
Name:	CIM Module weight 2.jpg
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Renovating a Team av11d Team Organization 2 18-04-2004 20:06
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
