Go to Post it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). - EricH [more]
Unread 13-01-2005, 23:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Skyway 4WD Help
Depends what kind of wheel you're using.
If it's got bearings in it, and you're driving the wheel, not the shaft, you can use any standard shaft (The most common is 3/8" I believe)
If you're driving the shaft and not the wheel (ie: the hub is keyed) you need a keyed shaft of that size
Either kind can be found at www.mcmaster.com
P.S. I'm moving this to the technical forum.
2001-2004: Team 100
2006-Present: Team 254
Skyway Wheel Hubs Nick R. Technical Discussion 2 10-01-2005 19:53
[OCCRA]: skyway wheels REPLY ASAP oaktown1188 OCCRA 3 04-10-2004 22:23
Need Skyway Tuffwheels Joshua May Kit & Additional Hardware 4 25-01-2004 01:31
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
skyway -> hubs/sprockets crakmunkey Technical Discussion 1 21-01-2002 14:56
