Re: Skyway 4WD Help
Places like mcmaster or msc would be great places to get more sprockets. You can access their websites at: http://www.mcmaster.com and http://www.mscdirect.com . You can also get more shaft from them as well.
Re: Skyway 4WD Help
Be careful what advice you're giving people. Those kit sprockets have been custom bored. If you buy standard sprockets from a source other than IFI, then you will need to have them pressed onto the shaft.
See THIS. |
Re: Skyway 4WD Help
You can use a bolt if you are putting it together like the kit does, at least that is what the instructions said if I read them correctly. We will be using bolts for our wheels as soon as we get them.
Re: Skyway 4WD Help
I'm so sorry, but I have found the section in the rules about the axles.
We still need help with the sprocket issue, thought. |
Re: Skyway 4WD Help
a 4 sprocket set (2 big ones for the skyway wheels provided[28 tooth], and two smaller ones for the gearbox output shaft[20 tooth]) ARE available at IFI robotics they come as a PACKAGE and are ~80$ ($@#$@#$@#$@#....)
btw what was it about the shafts that you found in the rules? |
Re: Skyway 4WD Help
In the Tips and Guidlines, they said that a ceartian type of bolt makes a good axle.
#7
Re: Skyway 4WD Help
wich bolt is that? we cant find that part and we gotta order our...
Thanks |
#8
Re: Skyway 4WD Help
Re: Skyway 4WD Help
Re: Skyway 4WD Help
Sorry if this was asked before. Thanks. ![]() |
#11
Re: Skyway 4WD Help
Re: Skyway 4WD Help
Go to page 1027 on http://www.mcmaster.com (just type the page in the search box). Scroll down a bit and you will see stamped base mount ball bearings. The are lighter than their cast iron coutnerparts. Also, pillow blocks are sometimes referred to as "mounted bearings"
#13
Re: Skyway 4WD Help
I recommend: Part No. 91236A644 From www.mcmaster.com But any equivalent part will work. JV |
#14
Re: Skyway 4WD Help
Re: Skyway 4WD Help
http://www.ifirobotics.com/kitbot.shtml |
| Skyway Wheel Hubs | Nick R. | Technical Discussion | 2 | 10-01-2005 19:53 |
| [OCCRA]: skyway wheels REPLY ASAP | oaktown1188 | OCCRA | 3 | 04-10-2004 22:23 |
| Need Skyway Tuffwheels | Joshua May | Kit & Additional Hardware | 4 | 25-01-2004 01:31 |
| Wheel Hub Connectors for Skyway Wheels | Wayne C. | Kit & Additional Hardware | 16 | 10-01-2003 07:16 |
| skyway -> hubs/sprockets | crakmunkey | Technical Discussion | 1 | 21-01-2002 14:56 |
