Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Unread 13-01-2005, 23:16
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Re: Skyway 4WD Help
Be careful what advice you're giving people. Those kit sprockets have been custom bored. If you buy standard sprockets from a source other than IFI, then you will need to have them pressed onto the shaft.
See THIS.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 13-01-2005, 23:35
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Re: Skyway 4WD Help
You can use a bolt if you are putting it together like the kit does, at least that is what the instructions said if I read them correctly. We will be using bolts for our wheels as soon as we get them.
our web site
Unread 14-01-2005, 00:18
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Re: Skyway 4WD Help
I'm so sorry, but I have found the section in the rules about the axles.
We still need help with the sprocket issue, thought.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 14-01-2005, 07:32
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
Re: Skyway 4WD Help
a 4 sprocket set (2 big ones for the skyway wheels provided[28 tooth], and two smaller ones for the gearbox output shaft[20 tooth]) ARE available at IFI robotics they come as a PACKAGE and are ~80$ ($@#$@#$@#$@#....)
btw what was it about the shafts that you found in the rules?
Nick .R. (Team 1009)
Unread 14-01-2005, 10:59
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Re: Skyway 4WD Help
In the Tips and Guidlines, they said that a ceartian type of bolt makes a good axle.
Anthony Rinaldi
Team 1132: 2003
Unread 14-01-2005, 20:59
Nick R.'s Avatar
Re: Skyway 4WD Help
wich bolt is that? we cant find that part and we gotta order our...
Thanks
Unread 14-01-2005, 21:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Skyway 4WD Help
Thanks
Any 3/8" diameter shoulder bolt with a shoulder the width of the wheel well should work fine.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-01-2005, 00:28
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Skyway 4WD Help
Ya, but get it 5 in. long The chasis was made to fit that size bolt just right.
Unread 25-01-2005, 19:20
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
Re: Skyway 4WD Help
what about putting the axle onto the chassis? Do they sell a piece like the one diagramed (attached - sorry im not a good drawler)? Have you seen something like that before that we could buy instead of having to machine ourselves - we have limited resources?
Sorry if this was asked before.
Thanks.
Unread 25-01-2005, 21:20
Cory's Avatar
AKA: Cory McBride
Re: Skyway 4WD Help
Thanks.
That's called a pillow block. Search on MSC, McMaster, sdp-si, etc for them. They're easy to find, the trick is getting some that don't weigh 10 lbs.
2001-2004: Team 100
Unread 25-01-2005, 21:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Skyway 4WD Help
Go to page 1027 on http://www.mcmaster.com (just type the page in the search box). Scroll down a bit and you will see stamped base mount ball bearings. The are lighter than their cast iron coutnerparts. Also, pillow blocks are sometimes referred to as "mounted bearings"
Unread 25-01-2005, 23:00
Re: Skyway 4WD Help
AWESOME!!! Thanks for your help!!!
Is there any difference between the shaft sizes, because the 1/2", 5/8", 3/4" shaft sizes each say they support the 3/8" axles (bolts) we bought.
In addition, can we use the polyester (with delrin raceway) base-mount bearings instead of the steel ones? I would think it would be lighter, however under the circumstances, is the increased price X3 worth the added benefit?
ALSO - if we were to use 1/2" axles/bolts (our two front wheels are andymark omnidirectional wheels) would the same "pillow block" work for it? Should we get a different size? I ask this because the steel section doesn't say it supports a bolt hole size of 1/2", only stainless steel has a 1/2" bolt hole size option at 5x price though.
One other thing - say you needed 8 of these (2 for each wheel, right) are we talking a lot of weight here? If they were 10 pounds each that would be 80 pounds!!!
Any help answering these rookie questions would be greatly appreciated.
Unread 14-01-2005, 21:02
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Skyway 4WD Help
Thanks
Any 3/8" dia bolt will work.
I recommend: Part No. 91236A644
From www.mcmaster.com
But any equivalent part will work.
JV
Unread 19-01-2005, 23:29
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Re: Skyway 4WD Help
The only bad thing about those sets are that you can't just get the sprockets for the wheels. Our team needs to buy 8 more to get our 6WD working and we are going to need to buy 4 sets at 80 bucks, that is not fun. We are currently trying to trade for them, otherwise, we are going to get them made. We hope to be able to get them for less than 40 bucks a piece
Elknise
Issaquah Robotics
Unread 20-01-2005, 00:02
JVN JVN is offline
@JohnVNeun
Re: Skyway 4WD Help
Originally Posted by elknise
The only bad thing about those sets are that you can't just get the sprockets for the wheels...
You may now buy individual sprockets from IFI.
http://www.ifirobotics.com/kitbot.shtml
Skyway Wheel Hubs Nick R. Technical Discussion 2 10-01-2005 19:53
[OCCRA]: skyway wheels REPLY ASAP oaktown1188 OCCRA 3 04-10-2004 22:23
Need Skyway Tuffwheels Joshua May Kit & Additional Hardware 4 25-01-2004 01:31
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
skyway -> hubs/sprockets crakmunkey Technical Discussion 1 21-01-2002 14:56
